This sounds like you are describing a 5 Volt relay. Does not get much simpler than that.I need help to build a simple Voltage activated switch,5 volt dc input,anyone got any simple circuits ?
Ok i have a circuit that is giving me 5 volt output and i need some kind of switch to activate another circuit for when that 5 volts is showing up,sorry i suck at explaining things.This sounds like you are describing a 5 Volt relay. Does not get much simpler than that.
Presumably I am misunderstanding what it is that you want.
by Jake Hertz
by Duane Benson
by Aaron Carman
by Jake Hertz
