Voltage across capacitor...
Discussion in 'Homework Help' started by ascotti, Jun 7, 2004.
  1. ascotti
    Jun 7, 2004
    Hi there,
    I am trying to write a software emulator for some circuits that were used in the 80's to generate sounds and effects in arcade machine. You can check:
    http://www.ascotti.org/programming/side/soundboard.htm
    to see for example the Space Invaders soundboard.
    I wonder if some of you can help with this piece of circuit:
    V1+ --- R1 --- C1 --- R2 --- C2 --- R3 --- V2+
    (all capacitors also connected to ground). I need to determine the voltage across capacitor C2.
    What I'm doing now:
    - I charge C1 via V1 and R1;
    - I charge C1 via R2 and C2 (doesn't seem to matter much);
    - I charge C2 via C1 and R2;
    - I also charge C2 via V2 and R3.
    The above doesn't seem to be correct, but with my limited knowledge I can't do better (I have read the relevant chapters of the great "All About Circuits" guide and worked out the examples up to the "Complex RC circuits" with Thevenin's theorem, but I don't know how to apply that to my case). :(
    If possible, I would like a formula that gives me the voltage across capacitor C2.
    P.S. I have attached a picture with the whole circuit (it's the "fire" effect from Galaxian by the way), the part I refer to is in the lower right corner.
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    where does the line of R46 & R48 lead to going upwards ( base on the picture you presented)
    what's the voltage supply
    what's that line connecting to the series R46 & R48 with a mark word (noise) :rolleyes: :unsure:
  3. ascotti
    Jun 7, 2004
    The R46 and R48 lines go upward to (one of) the control of a 4066 switch that is unused in this circuit. We can assume the lines are disconnected.
    The voltage supply is +5V and the NOISE line is connected to the output of a 7474.
  4. mozikluv
    Jan 22, 2004
    1,437
    hi,
    base on the picture R47 & R48 act as a voltage divider to C28. so whatever is the voltage ouput of pin 3 of the 7400 only half goes to C28.
    C29 holds the voltage of pin 5 of the timer to 1/3 of the supply in relation to the threshold voltage of the timer.
    as to the other circuit you have presented use the Kirchoff voltage law
