Voltage across capacitor gives a straight line
Discussion in 'Homework Help' started by hitmen, Sep 24, 2008.
  1. hitmen
    Thread Starter Active Member
    Sep 21, 2008
    159
    The thumbnail below shows an experiment that I am supposed to do for my lab. Apparently the answers were not given so I am seeking help on this forum.
    A 4Volt peak to peak voltage is connected as shown in the diagram.
    When the waveform across the resistor was measured, only a decreasing straight line was displayed.
    The only hint given is that there is a small resistance across the osciloscope probes.
    Can anyone enlighten me on the answer? :confused:
  2. mik3
    Feb 4, 2008
    4,846
    63
    Where is the diagram?
  3. hitmen
    Sep 21, 2008
    159
    Diagram uploaded.
  4. liitlefan
    Sep 24, 2008
    7
    maybe you can change your osciloscope's time scale,what u see maybe just part of waveform.good luck~
  5. Ron H
    Apr 14, 2005
    7,050
    657
    If the negative side of your generator is connected to earth ground (through the power cord), and your scope chassis is also connected to earth ground, you won't be able to measure the voltage across the resistor with a simple single-channel probe. You need either a differential probe, or to use both channels in A-B mode.
