Voltage across a resistor connected to a voltage source
Discussion in 'Physics' started by shespuzzling, Jan 4, 2010.
  1. shespuzzling
    Thread Starter Active Member
    Aug 13, 2009
    88
    If a resistor is connected to a voltage source, it will display the same voltage as the source does with the same polarity. Since these voltages are essentially equal and opposite, how is current able to flow at all?
    Also, does the voltage displayed across the resistor have anything to do with back-emf? If the source was AC, then current is indeed changing and so is the magnetic field so wouldn't a back-emf be generated?
    Thanks for your help!
  2. shespuzzling
    Aug 13, 2009
    88
    Eek, nevermind. I think I just figured it out.
