Vol 3 Chapter 2 Sec 9 2nd Paragraph - Junction field-effect transistors
Discussion in 'Feedback and Suggestions' started by Unregistered, Jun 19, 2009.
  1. Unregistered
    Thread Starter Guest
    In the Second Paragraph:
    "field effect transistor (FET) is a unipolar device, conducting a current using only one kind of charge carrier. If based on an N-type slab of semiconductor, the carriers are electrons. Conversely, a P-type based device uses only holes."
    Changed the middle sentence, Now the Paragraph reads:
    "field effect transistor (FET) is a unipolar device, conducting a current using only one kind of charge carrier. It is based on a N-type slab of semiconductor, where the carriers are electrons. Conversely, a P-type based device uses only holes."
  2. loosewire
    Apr 25, 2008
    1,584
    435
    It wou ld take 2 min to sign up,you are good with computer,fast.
    Welcome come join now. If there is no problems.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Thanks for taking the time to provide feedback on the material and apologies for the lateness of my reply.
    See: http://www.allaboutcircuits.com/vol_3/chpt_2/9.html
    I am inclined to believe the material reads better with the original statement, therefore do not recommend any chances to the e-book material.
    Dave
