Vol. 3 Ch. 4 Section 16
Discussion in 'Feedback and Suggestions' started by Wendy, Apr 9, 2009.
  1. Wendy
    Thread Starter Moderator
    Mar 24, 2008
    20,772
    2,540
    http://www.allaboutcircuits.com/vol_3/chpt_4/16.html
    3rd Sentence in BJT quirks.
    Reads...
    I would control hundreds of amperes of current, at hundreds of degrees C.
    Should be...
    It would control hundreds of amperes of current, at hundreds of degrees C.
    I'll list others typos for this chapter here as I find them unless requested not too.
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Cheers Bill.
    Please note that there are some images missing from Volume III Chapter 3 and 7 - this is an issue with the updating from AAC side and needs investigating - so no need to report these. Thanks.
    Dave
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I suspected as much. If you'd like I can draw to order.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The issue with the images has now been resolved, so you can close down MS Paint, Bill :)
    Dave
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Just a suggestion, post the sections that are new somewhere so they can recieve closer attention. Maybe a table or something. The older a paragraph is, the more likely it has been thoughly reviewed.
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I notice all sections in chapters 3 and 7 are tagged for proofreading - I'm not sure whether this is because there have been small changes across all sections or whether they have all been tagged so that the chapters in questions can be proofread in full for the purposes of consistency.
    I have asked Dennis to advise.
    Dave
  7. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    Chapter 3 has approximately doubled in size.
    Chapter 7 only has a new unijunction transistor section to complet it.
    Both chapters have had captions (and links to the captions) added to the images. Pay attention to captions. The Linux program "diction" was used to point out suspicious grammer. This results in minor changes throught the text. These activities can introduce errors into the text.
  8. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    Thanks Bill,
    I have entered the change in the ibiblio master copy
    Dennis Crunkilton
