VOIP project
Discussion in 'Embedded Systems and Microcontrollers' started by tuanvoi, Nov 5, 2008.
  1. tuanvoi
    Thread Starter Active Member
    Oct 31, 2008
    56
    Any body has some ideas about doing this project "VOIP" by using microcontroller (supports TCP/IP protocols). Thank you a lot.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Let's see:
    1. Digitize the speech to transmit.
    2. Break transmit stream into packets.
    3. Add headers.
    4. Send.
    5. Receive packets.
    6. Strip headers.
    7. Assemble into block of speech.
    8. Playback received speech through D to A converter.
    Good luck working out the details of the header. Don't forget to resolve the external IP address.
