Voice recorder
Discussion in 'The Projects Forum' started by CBM550, Dec 8, 2012.
  1. CBM550
    Dec 8, 2012
    I need a simple, small, voice recorder that will play back with a loop while the play button is pressed, then reset when released. The optimal device would be USB loadable so that I could load any audio file for playback and not have to mess with a microphone on the unit.
  2. MrChips
    Oct 2, 2009
    12,648
    3,459
    Your local consumer/hobby electronics store has a recordable greeting card.
    When you open the card a sound clip that you had previously recorded is replayed.
  3. djsfantasi
    Apr 11, 2010
    2,911
    881
  4. elec_mech
    Nov 12, 2008
    1,513
    193
    Welcome to AAC.
    Not sure about looping, but here is a USB loadable sound module that will play up to 200 seconds or stop when the switch is released. This comes with a sliding switch, but it can be replaced with another switch.
  5. John P
    Oct 14, 2008
    1,638
    225
    absf likes this.
