Voice changer faulty
Discussion in 'The Projects Forum' started by mangyver5223, Dec 13, 2011.
  1. mangyver5223
    Oct 22, 2011
    17
    Hi everyone, I build the telephone voice changer project for my final year project. The problem was, when I build and test it on breadboard, it doesn't give any output. I already check my connection and wiring but it still doesn't work. Was it my IC that I used are incompatible? please help me
    http://malaysia.rs-online.com/web/p/op-amp/7147418/
    http://docs-asia.electrocomponents.com/webdocs/0ec6/0900766b80ec6097.pdf
    LM358AN IC and datasheet
    http://malaysia.rs-online.com/web/p/audio-amplifier/0819674/
    http://docs-asia.electrocomponents.com/webdocs/0027/0900766b8002711e.pdf
    TDA7052 IC with volume control
    http://www.redcircuits.com/Page112.htm
    Original circuits
    Modified circuits
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
    It is impossible to say why it doesn't work. With the information you have provided, one can only guess.
    What does it do? Have you built it exactly like the schematic? Have you substituted any components? Does the power LED come on? Does the speaker make a click when you turn the circuit on and off? Have you checked that the IC's are getting power on the correct pins? Is the battery connected correctly and providing a full 9 volts under load? State what you have tried and what the results were.
    If you post a clear, close up photo of your assembly, it might be possible to see some issues.
  3. wayneh
    Sep 9, 2010
    12,368
    3,224
    Divide and conquer. You can diagnose one thing at a time. For instance, does the audio amplifier work when there's a signal at J1? Check the bias and output voltages at the op-amps.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The original project uses a TDA7052 power amplifier with a 10k log volume control and it works fine.
    But somebody changed the circuit to v2.0 and used a TDA7052A that has a DC volume control that needs a 1M linear volume control. 10k will mute it all the time.
    It will work if you replace the 10k log pot with a 1M linear pot.
    Which website "updated" the TDA7052 to a TDA7052A (v2.0) but used the wrong pot?
  5. mangyver5223
    Oct 22, 2011
    17
    hehe actually I forgot to change 10k to 1M on the sheet. I used 1M pot to this circuit. I do the design for ver 2.0 since the ordinary TDA7052 wasn't available at my market so I use TDA7052 with volume control. from ur opinion, does this 2.0 circuit work? I believe this circuit work since I only changed the IC TDA 7052 with adjustable volume ones. the other modification was just a minor (like adding LEDs and jack for microphone):)
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    What do you have for test equipment?
    A good DMM? Signal Generator? Borrow an oscilloscope? etc.
