Voice amplifier using opamp having gain 100
Discussion in 'Homework Help' started by harpooner, Oct 27, 2010.
  1. harpooner
    Oct 27, 2010
    Hello everyone.
    We have been given a project in our electronics lab to create a voice amplifier using an op amp having gain 100. We first need do pspice orcad simulation. Can anyone give a general idea of what i need. And is there any mic model in default library?? if not please post a link to one..
    Awaiting response...
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    I have relocated your thread to the homework section since it appears to be a class/lab assignment.
    hgmjr
  3. harpooner
    Oct 27, 2010
    ok.
    thank you.
    please i need some help. should i use an instrumentation amplifie ?!
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    A signal generator is used as the microphone in a simulation program.
    harpooner likes this.
  6. harpooner
    Oct 27, 2010
    Can anyone please suggest a decent amplifier circuit???
  7. JoeJester
    Apr 26, 2005
    3,393
    1,211
    The process usually works when you design ... and if you have questions, you post your design and the members will comment on your design. If it worked the other way, where the members designed and gave to you, you would be deprived of the pleasure and joy of learning.
