VO14642AT How do I bread board this
Discussion in 'Electronics Resources' started by rubicon99, May 3, 2012.
  1. rubicon99
    Apr 19, 2012
    46
    This is a solid state relay. Trying to bread board this and I burned a voltage regulator already. I know that I connect pin 1 to a ttl signal across a resistor, the second pin to ground the 4th pin to ground its the 5th and 6th pin i am confused about. One picture syas "DC" off the 5th pin and I thought I had to connect that to the power supply but another diagram has pin 6 connected to a voltage load and Vout. Where do I connect the power? Off a load to pin 6?
  2. BSomer
    Member
    Dec 28, 2011
    433
    106
    What kind of load (AC or DC) are you trying to switch on and off? The schematic that you see in the datasheet that shows pin 4 to ground is a test schematic. it is what Vishay used to show the characteristics of the SSR.
    If you are trying to switch an AC load pin 4 tied to the load and pin 6 goes to the voltage source, pin 5 is left floating. If you are switching a DC load then you tie pins 4 and 6 together and then to your voltage source and pin 5 goes to your load.
    Remember this is still a switch. So it goes in series with your load.
    +V ---> SSR ---> load ---> GND
    or for AC
    Line ---> SSR ---> load ---> Neutral
    osx-addict likes this.
