VLSI CMOS - Layout to Schematic help!
Discussion in 'Homework Help' started by Geza, May 18, 2009.
  1. Geza
    May 18, 2009
    7
    Hey guys,
    I've got my exam for VLSI coming up next week and need some help converting these layouts to schematics. Any ideas how it can be done or where I should look?
    Many thanks
  2. tuborggg
    Jan 3, 2009
    37
    Hi, you need a "map" to translate it. i.e. look at the attached file
      File size:
      16.1 KB
      57
  3. Geza
    May 18, 2009
    7
    thanks for your quick response :) I haven't been given a map for them, is it possible to guess which pattern is the n-type substrate which is metal 1 ... etc etc from the way it is drawn?
    Cheers
  4. Greg_R
    Member
    May 5, 2009
    11
    Yes, you can guess based on how the structures are drawn. The "legs" crossing the substrate are going to be either poly or M1. A poly between two metal legs = a transistor. Typically, for basic diagrams PMOS devices are drawn above NMOS devices (you'll see the two rows of diffusion in each problem). In the circuits without wire labels (VCC/VSS, cat, dog, etc.), start assigning arbitrary labels to keep things straight as you create the schematic. The thick horizontal wires in #2&3 are VCC (top) and VSS (bottom). Be careful though, I'm not sure if your prof wants you to guess at those labels or not.
    Note: the first diagram is evidently all NMOS devices...
