VK200 r.f choke maximum current
Discussion in 'Wireless & RF Design' started by tzitzikas, May 20, 2010.
Thread Status:
Not open for further replies.
  1. tzitzikas
    Thread Starter Active Member
    Jun 3, 2007
    41
    i have a linear amplifier which is using VK200 r.f choke (at input voltage). I would like to ask you which is the maximum current? Because when i operate the linear (7A current) the VK200 r.f choke is very very warm. thank you
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    The VK200 inductor is rated for 3 A continuous and 5 A peak.
    See the attached PDF.
    Bertus
  3. tzitzikas
    Jun 3, 2007
    41
    hi. i am thinking to replace the vk200 choke with some turns of wire, on ferrite bead.
    i have some pieces of this ferrite bead: FB-43-7351 from amidon (43 material)
    look here: https://www.amidoncorp.com/items/44
    how many turns i must use to have the same inductance with the vk200. i don't know how to calculate the number of turns, and also i don't know the vk200's inductance.
    (the circuit is an mw band (600-1800khz) linear amplifier),
    and the maximum current is 15A.
  4. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  5. tzitzikas
    Jun 3, 2007
    41
    If i use 4 vk200 (in parallel ) i will use the same inductance or 1/4 inductance, It will work?
  6. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
Thread Status:
