Vizio VW 42L acts crazy?
Discussion in 'General Electronics Chat' started by frank55, Jan 16, 2014.
  1. frank55
    Dec 6, 2013
    256
    10
  2. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    One of the buttons are stuck or corroded and making contact ... Try that and work from there..
  3. sheldons
    Oct 26, 2011
    616
    101
    common fault with this set-remove the pcb -remove the ch down button-throw it away and fit replacement-another cause can be firmware ive had that as well but try the button first-if on removal and reconnecting the board to the set again gives you a working set minus the ch down function you know what you need to do.......
