Visual studio Csharp Pulbic string
Discussion in 'Programmer's Corner' started by Dritech, Mar 2, 2014.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I am using two forms and will be using a sting named "test" in both forms. To so so, I declared the string as "public static string test;" in form1.
    For some reason I am getting the following error:
    Why is this happening please?
    spinnaker likes this.
  2. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Do you think it might make it a little easier if you posted the relevant code? Just a thought.
  3. chrisw1990
    Oct 22, 2011
    543
    41
    potentially, the namespace will be different between forms?
    Also, have you tried without static?
  4. Dritech
    Sep 21, 2011
    756
    5
    Hi. I did not post the code since it is quite long, but below is the part of the code which have to do this this string:
    Code in form 1:
    Code ( (Unknown Language)):
    1. public partial class Form_Home : Form
    2.     {
    3.
    4.         public static string test;  // initialize string
    1.
    2. string Send_code = "a";
    3. serial(test, Send_code);
    Code used in form 2:
    1. private void Use_COMport_Click(object sender, EventArgs e)
    2.         {
    3.             test = COMport_to_use.Text.ToString();
    4.             this.Close();   //Close this form
    5.         }
    6.
    By the way, I am using this code to interface (or try to) Visual Studio with the PIC microcontroller.
  5. Dritech
    Sep 21, 2011
    756
    5
    Hi, I removed the static and the same error is showing.
  6. spinnaker
    Oct 29, 2009
    5,115
    1,195
    So where is the error occurring?
    What class is private void Use_COMport_Click(object sender, EventArgs e) contained?
    And this code:
    You really need to provide enough information so people can help you.
  7. chrisw1990
    Oct 22, 2011
    543
    41
    have you tried referencing the variable through parent.test ?
    as your dialog box, i assume, comes up and takes priority (i.e.: you cannot interact with the originating form.)
    you are using two separate name spaces though.
    i.e.
    form1 uses test, has declaration of test etc.
    form 2 can see test if it references form1.
    I dont have any code at the moment with multiple dialogs (i hate them :p ) but try referencing it through form1.test or parent.test from the dialog
    Dritech likes this.
  8. Dritech
    Sep 21, 2011
    756
    5
    Thanks a lot chrisw1990 :)
    Including form1. solved the problem.
    Another quick question. If I use 10 buttons on Visual Studio to turn on/off 10 separate LEDs on the PIC, which is the best way to do it?
    I was doing it as below:
    If button 1 is pressed, send character "a" to the PIC.
    If button 2 is pressed, send character "b" to the PIC.
    If button 3 is pressed, send character "c" to the PIC.
    On the PIC I used if conditions as follows:
    If character = a, turn LED 1 on
    If character = b, turn LED 2 on
    Is there another way to do this more efficiently?
    Thanks in advance.
  9. ErnieM
    Apr 24, 2011
    7,443
    1,628
    Defining "efficiently" would help making a sensible reply.
    10 symbols for 10 commands maps well, but it makes me wonder if you can turn the LEDs off.
    The smallest this would fit into would be a 2 byte quantity, where individual bits ma to individual LEDs.
  10. chrisw1990
    Oct 22, 2011
    543
    41
    i agree with Ernie, simply for throughput efficiency as 16bits is a lot cheaper than 20bytes.. but it depends how often youre going to be executing this code. your pic can happily sit there with a 20 case switch statement in an interrupt routine when it receives the data if thats all its doing (light load anyway if not all its doing).
