Visual studio button problem
Discussion in 'Programmer's Corner' started by Dritech, Jun 20, 2014.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I am using a button will be used to blink an LED. When this button is pressed, I am turning on the LED for 5 seconds, and then turn it off for 5 seconds. The problem is that I want the LED to keep blinking as long as the button is pressed.
    How can I achieve this please? I tried using both BUTTON CLICK and BUTTON DOWN but non of them worked (function only executed once). Is there a method that as long as the button is pressed, the program keeps looping in that function?
    Note, I am programming using Csharp.
    Thanks in advance for your help.
  2. sirch2
    Jan 21, 2013
    1,008
    351
    Is this a hardware project or software only? You really need to post your code before we can help
  3. tshuck
    Oct 18, 2012
    3,531
    675
    You could create a timer whose tock event toggles the LED. Enable/disable the timer based on the state of the button.
  4. Dritech
    Sep 21, 2011
    756
    5
    It is software combined with hardware. Below is the part of the code:
    Code ( (Unknown Language)):
    1.
    2.         private void Button_up_MouseDown(object sender, MouseEventArgs e)
    3.         {
    4.             string Send_code = "a";
    5.             serial(use_COM, Send_code);
    6.         }
    7.
    Now I want the program to keep sending the character a as long as the button is pressed and not just send it once.
  5. tshuck
    Oct 18, 2012
    3,531
    675
    Why not let the hardware count the 5 seconds and just send go/stop commands when the button state changes?
  6. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the reply.
    Can I use a while look with the MOUSE UP?
    1.         private void Button_up_MouseDown(object sender, MouseEventArgs e)
    2.            {
    3.            while(mouseUP)
    4.             {
    5.             string Send_code = "a";
    6.             serial(use_COM, Send_code);
    7.             }
    8.            }
  7. tshuck
    Oct 18, 2012
    3,531
    675
    If you do that, you'll lock up your application.
  8. Brownout
    Jan 10, 2012
    2,375
    998
    You can spawn off a thread to blink the LED. Create the thread on the first click event and pass a parameter to tell it to blink or not. On subsequent events, first check to see if the thread has already been created, and if so, just pass a message to blink or not blink. It might sound complicated, but it's very easy.
  9. sirch2
    Jan 21, 2013
    1,008
    351
    I'd go with tshuck's suggestion of letting the hardware keep the LED flashing until told to stop.
