Visual basic cant open ximu exe
Discussion in 'Programmer's Corner' started by kuannygohcheetatt, Nov 23, 2014.
  1. kuannygohcheetatt
    Oct 31, 2013
    61
    Hi guys i am trying to use visual basic to open a ximu exe, but this error message pop up
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.FileNotFoundException: x-IMU API.dll
    at System.Diagnostics.FileVersionInfo.GetVersionInfo(String fileName)
    at x_IMU_GUI.Form_main.Form_main_Load(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    x-IMU GUI
    Assembly Version: 13.1.5067.29821
    Win32 Version: 13.1.5067.29821
    CodeBase: file:///C:/Users/User/Desktop/x-IMU-GUI-v13.1/x-IMU%20GUI.exe
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    x-IMU API
    Assembly Version: 14.0.5067.29643
    Win32 Version: 14.0.5067.29643
    CodeBase: file:///C:/Users/User/Desktop/x-IMU-GUI-v13.1/x-IMU%20API.DLL
    Tao.Platform.Windows
    Assembly Version: 1.0.0.5
    Win32 Version: 1.0.0.5
    CodeBase: file:///C:/Users/User/Desktop/x-IMU-GUI-v13.1/Tao.Platform.Windows.DLL
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  2. djsfantasi
    Apr 11, 2010
    2,914
    881
    From your error, the program can't find API.dll. It thinks there is one on your desktop.
    Could be a permissions issue, but without more information I can't be sure.
    Did you just install ximu? Can it run standalone?
    If it's a new install, try a re-install.
