Vista "updating" for three days
Discussion in 'Computing and Networks' started by #12, Jul 14, 2016.
  1. #12
    Thread Starter Expert
    Nov 30, 2010
    16,703
    7,339
    Patch Tuesday happened. My computer downloaded something. Now it has been running something in the background for 3 days at 50% of my CPU power.
    C'mon. That's enough computing power to copy my O.S. 20 or 30 times.
    Anybody know what's up with Micro$oft and Vista this week, or has my computer gone buggy?
  2. #12
    Nov 30, 2010
    16,703
    7,339
    and, yes, joey, I know installing the Linux hard drive will fix this, but it still won't run any feature on my printer except printing one face of one page at a time.
  3. joeyd999
    Jun 6, 2011
    2,757
    2,932
    Since I'm on you ignore list, anything I have to say wouldn't be helpful anyway.
  4. #12
    Nov 30, 2010
    16,703
    7,339
    I can still see* that you posted, and your post is not helpful.
    Have you ever considered NOT posting when you can't be helpful?
    Edit: *corrected grammar
  5. joeyd999
    Jun 6, 2011
    2,757
    2,932
    Can you consider not referencing me if you wish me not to respond?
    tom_s likes this.
  6. wayneh
    Sep 9, 2010
    12,388
    3,244
    When some mysterious thing is burning CPU cycles, my first step is to pull up the lists of running tasks and see what's at the top. If I can't recognize it or can't verify why it's running, I go to google it and get an idea. It's fairly rare that someone hasn't been there first. After that, finding a fix can be a hit or miss effort.
    tranzz4md, #12 and BR-549 like this.
  7. BR-549
    Sep 22, 2013
    2,181
    419
    It is secretly updating to 10.
    #12, wayneh and nsaspook like this.
  8. wayneh
    Sep 9, 2010
    12,388
    3,244
    That's not even funny. Too close to the truth.
  9. SLK001
    Nov 29, 2011
    851
    243
    Did you at least try hitting the reset button? Flash will do that to my machine while running Firefox. Sometimes processes don't properly terminate.
    Pull up Process Explorer and look for what is running at 50% (probably something running at 100% on one processor).
    And every machine has a reset button. Lately, it's been holding down the power button for 8 seconds. At the very worse, pull the plug or pull the battery.
  10. #12
    Nov 30, 2010
    16,703
    7,339
    According to, "fixit stick" the Avast antivirus had a virus, but it's not fixed.
    It's been running for 3 minutes and svchost.exe is running at 50% of my CPU power.
    Both processor cores are running at variable rates. They look normal for an update, except this thing should be running at 3% with my normal stuff running.
    And, yes, I turned it off and back on, several times in 3 days.
  11. BR-549
    Sep 22, 2013
    2,181
    419
    Who won?
  12. #12
    Nov 30, 2010
    16,703
    7,339
    I did an, "end process" on svchost.exe and exactly 3 minutes later it came back on at 50% CPU usage,
    so I killed it again.
    It came back on exactly 3 minutes later, but now it isn't using 50% of my CPU...and is still holding at about 3% CPU use nearly 2 hours later.
    If this starts the same way the next time I fire it up, I will just install a clean back-up copy.
    I wasn't really looking for you guys to help diagnose it, just, if anybody else is running Vista, did yours start running overtime, like something was poisoned in Patch Tuesday downloads?
  13. #12
    Nov 30, 2010
    16,703
    7,339
    Yep. Did that. svchost.exe
    a program so often used that there are usually several functions running under that label.
    However, this might be a fight between two programs. There was a time when Avast antivirus had a fight with Firefox, so I disabled Avast.
    After a few months, I let them both run, and they played well together for a year or two. Maybe they are fighting again.
    I'll try whacking Avast before I reload the O.S.
  14. SLK001
    Nov 29, 2011
    851
    243
    Load the Microsoft program Process Explorer. It will show what process svchost.exe is running (there are several svchost.exe instances running at any given time). It gives a much more detailed look at your running processes than task manager.
    Here is a version that will run on Vista.
    ProcessExplorer-14.zip
    tranzz4md likes this.
  15. ISB123
    May 21, 2014
    1,240
    531
    I had similar issue 2 years back it was caused by malware. Fixed it with malware bytes .
  16. joeyd999
    Jun 6, 2011
    2,757
    2,932
    Oh, yes! By all means run a zip file uploaded to the internet. That'll fix your problem...
  17. SLK001
    Nov 29, 2011
    851
    243
    Careful, dude... I have a button right here that when I push will remotely shut down your pace maker.
    tranzz4md and #12 like this.
  18. #12
    Nov 30, 2010
    16,703
    7,339
    I think my computer has a hardware problem.
    I backed it up by 7 days...no help.
    I backed it up by 15 days...no help.
    I backed it up to February 2016...no help.
    Beginning to suspect the RF board that connects to the router.
    Wireless Adapter?
    Anyway...still working on it, and I feel lucky to get on The Internet at all, considering the computer keeps complaining that it can't connect to Microsoft Update.
  19. shteii01
    Feb 19, 2010
    3,504
    512
    They can download it from M$.
  20. #12
    Nov 30, 2010
    16,703
    7,339
    Installed the Linux HDD. It's idling along at about 4% CPU power. Must be a Micro$oft problem.
