visitor counter cum token number display
Discussion in 'Programmer's Corner' started by laxmi, Oct 7, 2009.
  1. laxmi
    Jun 19, 2009
    14
    Hello Sir/Madam,
    As im doing this project using pic-16f877a microcontroller.
    concept of output: i need to display number of persons enter as well as using sensor and also token number display .
    in main program i wrote code of visitor & in interrupt service routine i wrote code of token display.
    for visitor -00-99 display
    for token display- max_size of array we can store is 25.
    main-program:
    Note :in this code as im using single controller so i used for 7-segment display PORTA & RE0(g) for token & PORTD for VISITOR.
    while(1)
    /*for up-counter 00-99*/
    if(IN_SENSOR)
    while(IN_SENSOR)
    continue;
    DelayMs(50); // Delay for debounce
    if(count<=99)
    count++;
    display_number_both_tens_unit(count);
    else
    { /* for Down-counter*/
    if(OUT_SENSOR)
    while(OUT_SENSOR)
    continue;
    DelayMs(50); // Delay for Debounce
    count--;
    } //End of while
    isr:
    static void interrupt
    isr(void)
    if(RCIF&& RCIE)
    if(arr_ptr<max_size)
    num1=getch();
    num2=getch();
    read_value=(((num1*10)+num2)-16);
    input_arr[arr_ptr]=read_value;
    arr_ptr++;
    if(arr_ptr==max_size)
    putch(' ');
    putch('A');
    putch('F');
    putch('F');
    //RCIF=0;
    else if(INTE&&INTF)
    int_ptr=0;
    tens_place=((input_arr[int_ptr])/10);
    unit_place=((input_arr[int_ptr])%10);
    putch(' ');
    putch('A');
    putch(tens_place|0x30);
    putch(unit_place|0x30);
    if((RB0)==1) // here im gettin problem if i use if statement the result is unit_place is same as tens_place . if use while(RB0) this will be interrupt only means not possible to go main program as visitor counter
    if(tens_place ==1)
    g=1;
    else if(tens_place == 0)
    g=1;
    else if(tens_place==7)
    g=1;
    else
    g=0;
    TOKEN_DISPLAY=Display(tens_place);
    DIGIT1_tens_token=0; //Enabling DIGIT1_tens
    DelayMs(2); //wait for few milliseconds
    DIGIT1_tens_token=1; //Disabling DIGIT1_tens
    if(unit_place == 1)
    g=1;
    else if(unit_place == 0)
    g=1;
    else if(unit_place == 7)
    g=1;
    else
    g=0;
    TOKEN_DISPLAY=Display(unit_place);
    DIGIT2_unit_token=0; //Enabling DIGIT2_unit
    DIGIT2_unit_token=1; //Disabling DIGIT2_unit
    for(j=0; j<max_size; j++)
    input_arr[j]=input_arr[j+1];
    arr_ptr--;
    INTF=0;
    Please Help me out.
    Thanks in advance.
