visible lighting communication
Discussion in 'The Projects Forum' started by sgltang, Nov 19, 2013.
  1. sgltang
    Nov 19, 2013
    Hi all,
    I am working on a project about the driving circuit design of visible lighting communication using LED bulb, but I am really weak at circuit design and I cannot find any useful paper to help me with the design of such circuit. Is there any book or paper recommended?
    Any advice will be valued! Thanks!
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    sgltang likes this.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Look up modulation.
    All the transmission side requires is modulating a light source(LED) with data - you must specify the modulation technique.
  4. sgltang
    Nov 19, 2013
    I know the basic theory of modulation and I am thinking about modulating the signal I want to transmit by Manchester code, but how to realize the modulation using real circuit components? Is there any information I can refer to?
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    Go read the link I gave you.
  6. tshuck
    Oct 18, 2012
    3,531
    675
    Seconded, it looks like a good resource.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    This was neither feedback nor a suggestion, so I have moved it to a more appropriate forum.
