Visible Light Communication
Discussion in 'The Projects Forum' started by thebigk7, Aug 15, 2011.
  1. thebigk7
    Aug 15, 2011
    I am doing a project on Visible Light Communication using LEDs. I need to send serial data from the laptop to LED. Any ideas for implementing this transmitter part?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, many laptops already have IrDA's in them, or infrared datalinks.
    Have a read on this Microsoft article:
    http://support.microsoft.com/kb/313296
    If you can figure out that protocol, you might be able to replace the existing IR LED and receiver with visible light emitters and receivers. However, you could also easily ruin your laptop. :eek:
    If your laptop has a USB port, you might consider using that as an interface point, as it could supply a bit of power (maybe 200mA or so), and communication for your interface. You'll need to write driver software for it.
    thebigk7 likes this.
  3. KJ6EAD
    Apr 30, 2011
    1,426
    363
    Make it big and powerful so it's all the receiver sees.
