Visible light communication system Receiver
Discussion in 'The Projects Forum' started by sycandy06, Jan 5, 2010.
  1. sycandy06
    Jan 5, 2010
    Hi, I'm doing a project of using LED light to transmit data. for the receiver part, i've to start with a Bandpass filter which center frequency at 100kHz. I've designed a second order Sallen key Bandpass, but the result of the schematic doesn't at 100kHz..It has a little bit distortion. How can i fix this problem??
  2. JDT
    Feb 12, 2009
    Are you trying to build this 100kHz band-pass filter with an op-amp?
    If so, that will be the source of your trouble. Unless you use a seriously high-frequency amplifier.
    Best to use a passive filter at this frequency. A simple L-C tuned circuit will do. More complicated designs exist but will need a lot of circuit elements and mathematics!
  3. maogibba
    Jan 4, 2010
  4. thebigk7
    Aug 15, 2011
    hi, even I'm working on visible light communication project, any ideas on implementing the transmitter section using a laptop and LEDs ?thanks in advance
