virtual ground
Discussion in 'General Electronics Chat' started by dileepchacko, Aug 7, 2008.
  1. dileepchacko
    Thread Starter Active Member
    May 13, 2008
    102
    Hi All
    What is the exact meaning of the virtual ground of an op-amp, why we are calling as virtual ground. Is the point is directly connected or internally connected.
  2. studiot
    Nov 9, 2007
    5,005
    515
    The answers to your question can be found here
    http://www.allaboutcircuits.com/vol_3/chpt_8/5.html
    Note in particular the virtual ground only applies to the inverting input of an amplifier, and that it is not directly connected to ground, either internally or externally.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    It is not directly connected, but if you were to measure it with a meter it appears to be ground, hence the name. The op amp does an excellent job of making that point "appear" to be ground, even to instrumentation.
