Vintage relay search
Discussion in 'General Electronics Chat' started by inwo, Jun 26, 2014.
  1. inwo
    Nov 7, 2013
    2,435
    315
    Repaired a brake failure on a 50+ year old overhead crane Monday.
    A cylinder fell out of a coil.
    The problem had them shut down so I had no time to research or even figure out how it failed.
    I just put a clamp top-side on the cylinder to keep it in place.
    First thought was that it was a mercury relay.
    It was marked with "seconds" however. Must be a delay relay.
    I'm doing a search without much success. Anyone know what this might be called?
    Coil part is about 2" square. 1" thick. 1" hole.
    Cylinder part fits thru hole ~5" long.
    I want to be ready for the next time.
  2. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,512
    I am guessing the coil is DC powered? Being that old, it could be a oil dash-pot (or?) delay. the piston drives oil out at a per-determined rate.
    Just a guess!
    Getting a replacement may be a head ache :p
    Do you have the Crane schematic?
    Max.
  3. inwo
    Nov 7, 2013
    2,435
    315
    The schematic is available. I haven't found the brake control part yet though. It's just shown as a black box.
    Somewhere should even be part numbers.
    No dash-pot control valve or adjustment other than sliding the cylinder.
    Can't picture how that would work.
    Right now I'm just curious. No pressing need.
    Not 100% sure it's a timer.:confused:
    Absolutely amazing how rugged these crane controls were made.
    Just now replacing some contactors and auxiliarys.
    Mostly metal fatigue, not electrical failure. Sometimes it's just a wire terminal broke off next to the screw.
  4. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,512
    Does the piston part contact/actuate anything else?
    It is not just the pin to operate the brake, is it working in a time delay fashion now?
    I imagine the lift motor is AC wound rotor for speed control?
    Max.
  5. inwo
    Nov 7, 2013
    2,435
    315
    Kind of like fig.1, but leads come out bottom.
  6. MrCarlos
    Jan 2, 2010
    400
    134
  7. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,512
    Seems to be similar that it possess a dash pot delay of some kind?
    Max.
