Vinegar Battery. :)
Discussion in 'Off-Topic' started by Lightfire, Apr 19, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    Howdy!
    I made a vinegar battery very a few minutes ago. XD
    I made 3 vinegar batteries (series connection) and one more.
    and connect them each other by parrallel circuit.
    EH? can't even light up the LED very brightly.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It makes you appreciate how much power is stored in commercially made batteries.
  3. Markd77
    Sep 7, 2009
    2,803
    594
    Do you mean like this?
    It's better to remove the extra one on its own because current from the 3 will actually flow backwards through the single one.
    Also see if it gets better if you move the electrodes closer together (don't let them touch).
      File size:
      2.3 KB
      60
  4. Lightfire
    Oct 5, 2010
    690
    21
    No, it's not like that.
  5. QuadTech
    Apr 19, 2011
    6
    Did you ever have to make a lemon battery cell in school as a child? If you have enough lemons, you can actually charge an iPod. Albeit, connecting the charger to the lemon battery is a bit more complicated than constructing the battery itself.
  6. magnet18
    Dec 22, 2010
    1,232
    125
    Do you have a multimeter?
    If you can get a couple volts try making more and putting them in parallel for more current, or change the batteries so that they have more metal in the vinegar, or try to find a higher concentration of vinegar
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    @ Lightfire
    I 'll make the correction, just to prevent bad habits from sticking:
    It's called a multimeter, not multimer.
    I 've been calling a certain software Utilboard instead of Ultiboard. I found it out last week. It's very hard to call it correctly now.
  8. magnet18
    Dec 22, 2010
    1,232
    125
    Whoops, that was me, wasn't it :rolleyes:
    I fixed it.
