Video transmit using PWM
Discussion in 'The Projects Forum' started by roboticvn, Jul 13, 2014.
  1. roboticvn
    Jul 9, 2014
    47
    I have video transmission circuit block diagram but I can not draw the circuit details. Can you help me? Thank you
    I need a IC for 15MHz PWM with Vin=2V
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  3. roboticvn
    Jul 9, 2014
    47
    This is led driver
    15MHz PWM is really used in journey which I read.
    I actually have a lot of problems. The this led driver use for both audio and video transmit. I don't under stand effect of two TLV3502 op-amp, mosfet, level shifter. I intend to use TLV3502 for PWM but I don't know how configured for it. I expect output is TTL level. Can you help me? I really need help. Thank you
