Video image mixer in a split screen (two inputs, one output)
Discussion in 'The Projects Forum' started by Barenca, May 21, 2015.
Thread Status:
Not open for further replies.
  1. Barenca
    May 21, 2015
    Hi everybody.
    I want to build a circuit for my car that shows me the front and rear camera in the same screen (splitted).
    Is this possible with a simple circuit?, any ideas about how to build the circuit?
  2. crutschow
    Mar 14, 2008
    13,496
    3,373
    That is a complex function that can't be done with a simple circuit.
    To start, you need to know what the video format is.
    Edit: You best bet may may be to buy a split monitor such as one of these or this.
  3. ranch vermin
    Member
    May 20, 2015
    85
    You could program it, I recommend windows media foundation for the library. Actually doing it in hardware is old school, and really cool if you did it tho. :)
  4. crutschow
    Mar 14, 2008
    13,496
    3,373
    Program what?
    Are you proposing putting a computer in the loop?
  5. Barenca
    May 21, 2015
  6. ranch vermin
    Member
    May 20, 2015
    85
    I dont mean putting a computer in the loop, i mean just using a computer by itself. :)
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,691
    1,297
    When CBS introduced the quad split screen, what most people don't realize is that it was a purely mechanical effect. The took the cases and frames off of four monitors so the screens could be pushed as close together as possible, and pointed a camera at the assembly. An all electronic split screen came years later. I installed the first one in Columbus.
    All RCA connectors implies all NTSC composite video, which makes an all electronic split screen very easy with Maxim chips. BUT ... the two cameras must be synchronized, and most small low cost cameras will not sync up to an external signal. So if you don't want to do this with a pc that has two video capture cards, then you need to buy a split screen device that has frame synchronizer built in.
    ak
    ranch vermin likes this.
  8. crutschow
    Mar 14, 2008
    13,496
    3,373
    I fail to see how that helps solve the OP's problem. :confused:
  9. ranch vermin
    Member
    May 20, 2015
    85
    If its a crt, cant you hack the position of the ray gun? Since its signal controlled, maybe you affect the signal to do it.
  10. blocco a spirale
    Jun 18, 2008
    1,460
    370
  11. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,386
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
