Vibration sensor, RF-sending/receiving
Discussion in 'The Projects Forum' started by nerdegutta, Dec 16, 2009.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,572
    807
    Hi.
    I've built this:
    http://www.jameco.com/Jameco/PressRoom/recipe4.html
    With success. When it detects vibration, the LED lights up.
    Now I want to improve it, by adding a radio sender to it. This is the idea:
    The vibration sensor, detects vibration, and instead of lighting the LED, I want it to send a radio signal. Approximately 100-200m. Another sensor, or radio receiver, picks up the signal, and is sending 2-5 v to an output pin. This pin is hooked up the the printerport of one of my computers, and is activating some software. The software part is no problem.
    Does someone have any suggestions on how to solve this little case?
    I was wondering to try this:
    http://www.jameco.com/Jameco/PressRoom/rocket.html
    but I'm not sure how to hook it up at the computer side.
    Nerdegutta
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    Since this is a simple ON/OFF signal, you could either write a parallel port or a serial port script to detect this. However, for a few bucks more and a lot less time you can get a USB port DAQ module such as what B&B Electronics sells, and not have to worry about writing interface code. This computer control and acquisition stuff is pretty addictive anyway, so you'll soon use the additional functions of a DAQ module. :)
    eric
  3. nerdegutta
    Dec 15, 2009
    2,572
    807
    I know, but the Christmas holidays are coming up, and between all the eating, and social gatherings with the family, I need some quality time alone... :)
    nerdegutta
