I have been working on my project, where I am using a piezo vibration sensor and an electret microphone connected to an LCD through an Arduino microprocessor.
I need to tweak it a little and hope that you guys could help me.
I was told that for the sound portion I need to have a sampling rate of at least 40kHz (assuming I want to measure up to 20kHz, and I learned from my comm class something like fs = 2f). How do I apply it to the Arduino? Through some research I found that I need to set the prescaler to 16? How do I apply that to my code?
When running the code below with only vib() inside the void loop(), it outputs good values . But when running this code like below, I get an erroneous output for the vibration portion, because it outputs the values over time, (instead of outputting it every time I touch the vib sensor). It summarizes the values somehow and gives me a strange output that seems to be almost completely random.
I do want the output to be timed, instead of having to touch it every time, but how can I fix the output? Can you guys help me please?
Thank you so much!
Thank you so much!
Rich (BB code):
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
const int ledPin = 13; // led connected to digital pin 13
const int knockSensor = A0; // the piezo is connected to analog pin 0
const int threshold = 5; // threshold value to decide when the detected sound is a knock or not
int sensorReading = 0; // variable to store the value read from the sensor pin
int ledState = LOW; // variable used to store the last LED status, to toggle the light
int sum = 0;
int values = 10;
int i = 0;
const int sampleWindow = 50; // Sample window width in mS (50 mS = 20Hz)
unsigned int sample;
void setup() {
lcd.begin(16, 2);
pinMode(ledPin, OUTPUT); // declare the ledPin as as OUTPUT
Serial.begin(9600); // use the serial port
void vib()
// read the sensor and store it in the variable sensorReading:
sensorReading = analogRead(knockSensor);
// if the sensor reading is greater than the threshold:
if (sensorReading >= threshold) {
// toggle the status of the ledPin:
ledState = !ledState;
// update the LED pin itself:
digitalWrite(ledPin, ledState);
if (i >= values)
i = 0;
sum = sum/values;
//Serial.println(sum);
lcd.setCursor(0, 1);
lcd.print(sum);
sum = 0;
else
sum += sensorReading;
i++;
delay(10);
void Micro()
unsigned long startMillis= millis(); // Start of sample window
unsigned int peakToPeak = 0; // peak-to-peak level
unsigned int signalMax = 0;
unsigned int signalMin = 1024;
// collect data for 50 mS
while (millis() - startMillis < sampleWindow)
sample = analogRead(1);
//Serial.println(sample);
if (sample < 1024) // toss out spurious readings
if (sample > signalMax)
signalMax = sample; // save just the max levels
else if (sample < signalMin)
signalMin = sample; // save just the min levels
peakToPeak = signalMax - signalMin; // max - min = peak-peak amplitude
double volts = (peakToPeak * 3.3) / 1024; // convert to volts
delay(100);
//Serial.println(volts);
lcd.setCursor(0, 0);
lcd.print(volts);
void loop() {
Micro();
vib();
