Vibration activates led
Discussion in 'The Projects Forum' started by susannah, May 30, 2013.
  1. susannah
    Thread Starter Active Member
    Feb 14, 2010
    87
    I would like to automatically turn led on (and keep it on) when vibration is detected. Vibration comes from gadget which has vibration motor. How i can do that? Thanks!
  2. wayneh
    Sep 9, 2010
    12,396
    3,246
    Why not just measure the voltage going to the power terminals of the motor? A comparator would work great for that.
    You might be able to arrange a wire that would make contact with the rotating part, if it has one.
    An accelerometer mounted near the vibration would certainly pick it up. Or even a microphone, I suppose.
  3. Dodgydave
    Jun 22, 2012
    5,163
    774
    You could use a Piezo speaker to detect the vibration, and feed it into a 555 chip.
  4. susannah
    Feb 14, 2010
    87
    Thanks, this looks promising.
    I have "555 Timer Sparkfun COM-09273". Can i use it?
    There is 2 resistors in top left. Are these 470R?
    What LED resistor value should i use?
  5. edwardholmes91
    Member
    Feb 25, 2013
    200
    20
    I was going to suggest the same thing Dodgydave, a piezo element and a 555 timer.
  6. circuitfella11
    Member
    May 10, 2013
    56
    5
    if the typical LED's, you can use 100k resistors.. if not, refer it to the input that you will use and the LED's capacity..
  7. susannah
    Feb 14, 2010
    87
    Can i use fancy piezo like this and can it be used without Arduino?
    Grove - Piezo Vibration Sensor Seeedstudio SEN04031P
    http://www.seeedstudio.com/depot/grove-piezo-vibration-sensor-p-1411.html?cPath=25_26
    My second choice would be
    Piezo Disk Vibration Sensor DFRobot DFR0052
    http://www.dfrobot.com/index.php?route=product/product&filter_name=piezo&product_id=399
    or
    Piezo Vibration Sensor - Small Horizontal Sparkfun SEN-09198
    https://www.sparkfun.com/products/9198
    or do i need to use just plain element like this:
    Piezo Element Sparkfun SEN-10293
    https://www.sparkfun.com/products/10293
