VHF / SSB installation
Discussion in 'The Projects Forum' started by white_rg, May 23, 2008.
  1. white_rg
    Mar 19, 2008
    hello to all , i will install a SSB radio on my steel boat [ emission maxi 150 watt ] but i need to ground it .i think it is the same as grounded a SSB radio on "earth" and i read articles on the web telling me that i need to use 0.15 F capacitors but they didn't tell how many and how this value ( 0.15F) was calculated.
    So any advices / docs/websites from vhf/hf/SBB "experts" will be greatly appreciated .many thanks in advance
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I've heard of folks operating maritime mobile, but I'm pretty sure they don't drop a copper rod into the water.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I think you will find the hull is fairly well grounded. Anything electrically tied to the hull is going to be grounded. The water surface makes a really nice ground plane, too.
    What function are the capacitors supposed to do?
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I'm curious about what radio service and VHF frequency allocation allows you to exceed 1500 Watts? At those power levels you will want to conduct an RF safety evaluation and make sure nobody can get an RF burn from putting their lips on the antenna with the PTT key down. Have your ever seen an RF burn? Nasty buggers!
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Depending on frequency and circumstances of exposure, those power levels can cause cataracts and/or sterility in addition to burns
  6. white_rg
    Mar 19, 2008
    hello to all ,
    thank for your responses , sorry but i think a mistake i should have write : emission maxi 150 watt .I am very confuse because the dealer i went to see was more "seller" than technician ( Furuno SSB )
    "What function are the capacitors supposed to do?" i dont know , because he refused to give me the details of the ssb installation ( a good SBB is [ very ] expensive ); for what i have read i think when the sbb is emetting , there is an electric arc
    maybe the function of the capacitors is for that.
  7. loosewire
    Apr 25, 2008
    1,584
    435
    White RG -Go to (http--www.frallon.us-ssb.pdf ) Help guy's find this site and give a
    click on to help.The explaination of grounding on boat's will be helpful, the curcuit
    information may used in the e-book. I think it excellent information,check out the
    theory.Check out plated copper Vs copper wire to ground.How many star's.
    LOOSEWIRE
  8. white_rg
    Mar 19, 2008
    thank you LOOSEWIRE , but the url doesn't seem to work
  9. loosewire
    Apr 25, 2008
    1,584
    435
    That why I noted for help from members,It all there every thing you wanted and more for every member. DAVE ,Please help
  10. loosewire
    Apr 25, 2008
    1,584
    435
    Search Eric Steinberg,Farallon Electronic's,Got the same results.
    Try it now.LOOSEWIRE
  11. white_rg
    Mar 19, 2008
    ok have it .thank you
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Depending on features and frequency bands an SSB radio is not necessarily an expensive proposition compared to a ship. 150 Watts is a reasonable power level for a marine radio in the HF region of the RF spectrum, 3 MHz - 30 MHz. Prices for an SSB rig for the HF bands should be in the $300 - $3000 range. You said these were VHF radios which implies a coverage in the 30 MHz - 300 MHz region of the RF spectrum. In the VHF spectrum this power level may well get you into more expensive territory.
    My 2 meter (144- 148 MHz.) base station is an ICOM 2200. It puts out 65 Watts and cost $130.00. It is not an SSB rig, but a narrow band FM. For independent advice on your radio decisions check out a local amateur radio club. With any luck you'll find an Elmer (mentor) more than willing to give you some help and advice for a ride on the boat.
  13. JoeJester
    Apr 26, 2005
    3,401
    1,218
  14. loosewire
    Apr 25, 2008
    1,584
    435
    Did you read the marine grounding,good info.
    LOOSEWIRE
  15. JoeJester
    Apr 26, 2005
    3,401
    1,218
    I've read the article. It mentioned steel hulls don't have the ground plane problems that occur with fiberglass hulls. It doesn't address the specific issue the OP had in mind (the capacitors).
    For the OP (original poster):
    I'm curious as to why the purchased radio didn't have an installation manual. What is model and manufacturer of your radio? Manufacturers don't typically leave you hanging high and dry (so to speak).
  16. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Unscrupulous dealers might have no qualms about sticking it to you however.
  17. JoeJester
    Apr 26, 2005
    3,401
    1,218
    That may be. However, the owners manual is probably online.
  18. Externet
    Nov 29, 2005
    776
    57
    For the HF transceiver, the best suggestion I can give after earning a living in marine electronics is to make a bronze puddle of at least a couple inches diameter by brazing onto solid ultraclean grinded-to-shiny metal and weld an at least ½" bronze bolt head down to the puddle to connect your coaxial shields, all this done next to the base of the antenna and antenna tuner location. Use flat bronze washer and bronze nut.
    After VERY solid soldered terminals are attached and all tests good, pour silicone sealer around.
    The ship/transceiver battery must have negative to hull.
    The 2m VHF antenna is usually colinear and requieres no grounding. But make sure its cable does not flag around.
    Miguel
