1. mentaaal
    Thread Starter Senior Member
    Oct 17, 2005
    451
    Hey guys, we were being shown how to use if statements in vhdl and i cannot get it to work! Also my lecturer hasnt bothered to reply to my question regarding this so i would like to know what i am doing wrong before the exam.
    This code compiles ok when the if statement is removed.
    Thanks for the help!
    When i try to analyse the code below with quartus II it says the folowing:
    Error (10500): VHDL syntax error at demux4-to-16.vhd(16) near text "if"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
    Error (10500): VHDL syntax error at demux4-to-16.vhd(36) near text "if"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture"
    Error: Quartus II Analyze Current File was unsuccessful. 2 errors, 0 warnings
    Info: Allocated 190 megabytes of memory during processing
    Error: Processing ended: Fri Dec 14 12:27:01 2007
    Error: Elapsed time: 00:00:01
    The code i wrote was for a demultiplexer model:
    library IEEE;
    use IEEE_std_logic_1164.all;
    -- the above two lines instructs the program to use the two standard librabries
    entity demux is
    port( sel: in_std_logic_vector ( 3 downto 0 );
    din: in_std_logic;
    enable , ebar : in_std_logic;
    dout: in_std_logic_vector ( 15 downto 0));
    end demux;
    architecture behaviour of demux is
    begin
    if enable = '1' and ebar = '0' then
    dout <= "1111111111111110" when sel = "0000" else
    "1111111111111101" when sel = "0001" else
    "1111111111111011" when sel = "0010" else
    "1111111111110111" when sel = "0011" else
    "1111111111101111" when sel = "0100" else
    "1111111111011110" when sel = "0101" else
    "1111111110111110" when sel = "0110" else
    "1111111101111110" when sel = "0111" else
    "1111111011111110" when sel = "1000" else
    "1111110111111110" when sel = "1001" else
    "1111101111111110" when sel = "1010" else
    "1111011111111110" when sel = "1011" else
    "1110111111111110" when sel = "1100" else
    "1101111111111110" when sel = "1101" else
    "1011111111111110" when sel = "1110" else
    "0111111111111110" when sel = "1111";
    end if dout <= "1111111111111111";
    end behaviour;
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    http://esd.cs.ucr.edu/labs/tutorial/
    if ((enable = '1') and (ebar = '0')) then
    I've never used that language but the code snipped from here suggests this format. I think end if needs to be on a separate line.
    http://esd.cs.ucr.edu/labs/tutorial/AND_gate.vhd
  3. mrmeval
    Jun 30, 2006
    833
    Oh and you might look at the case statement on that dout block.
  4. mentaaal
    Oct 17, 2005
    451
    hi thanks alot for that, i will give that code a shot tonight and let you know if it worked.
  5. mentaaal
    Oct 17, 2005
    451
    Ok i tried what you said and quartus II is still complaining. The relevent altered code is here:
    begin
    end behaviour;
    the errors it said are here:
    Info: Running Quartus II Analyze Current File
    Info: Version 7.2 Build 151 09/26/2007 SJ Web Edition
    Info: Processing started: Sun Dec 16 12:48:32 2007
    Info: Command: quartus_map --read_settings_files=on --write_settings_files=off demux4-to-16 -c demux4-to-16 --analyze_file=C:\altera\72\quartus\demux4-10-16\demux4-to-16.vhd
    Error (10500): VHDL syntax error at demux4-to-16.vhd(16) near text "then"; expecting "<="
    Error: Quartus II Analyze Current File was unsuccessful. 3 errors, 0 warnings
    Error: Processing ended: Sun Dec 16 12:48:33 2007
    Not even my lecturer knows what the problem is hahahahaha
  6. WCraig62485
    Jan 9, 2008
    Have you tried using a process? I usually use those when doing 'if' statements. The beginning of the process may look something like:
    process (enable, ebar)
    if(...)
    end if;
    end process;
