vhdl seven segment--please help
Discussion in 'Programmer's Corner' started by marwa, Jan 6, 2008.
  1. marwa
    Jan 6, 2008
    how can i display an integer number on the seven segment ??
    i know how to display the number if it ranges from 0 to 9 using one segment
    but i'm having a little trouble with displaying numbers from 0 to 9999 using 4 segments ????
    i need to know this; but i have little clue i would appreciate any help!!
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Ah...you need to convert the binary integer into decimal digits. For example if you have an 8 bit integer you can convert that to three decimal digits. If you have a 16-bit integer you can convert that to 5 decimal digits.
    The standard technique is the repeated computation of quotient and remainder by powers of 10.
    Code ( (Unknown Language)):
    1.
    2. DIGIT0  DIGIT1  DIGIT2  DIGIT3  DIGIT4
    3.
    4. If X is a 16-bit integer,
    5. and / is the operator for quotient,
    6. and % is the operator for remainder.
    7.
    8. DIGIT0  = X / 10,000
    9. REM0    = X % 10,000
    10.
    11. DIGIT1  = REM0 / 1,000
    12. REM1    = REM0 % 1,000
    13.
    14. DIGIT2  = REM1 / 100
    15. REM2    = REM1 % 100
    16.
    17. DIGIT3  = REM2 /10
    18. DIGIT4  = REM2 % 10
    19.
  3. marwa
    Jan 6, 2008
    thanx million that was alot of help
  4. haran
    Apr 6, 2008
    42
    can you teach me how to display the number if it ranges from 0 to 9 using one segment using vhdl language for maxplus+
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Use a WITH/SELECT statement like this:
    1.
    2. WITH bcd_in SELECT
    3. out_segs <= "0000001" WHEN "0000",
    4.             "1001111" WHEN "0001",
    5.             "0010010" WHEN "0010",
    6.             "0000110" WHEN "0011",
    7.             "1001100" WHEN "0100",
    8.             "0100100" WHEN "0101",
    9.             "1100000" WHEN "0110",
    10.             "0001111" WHEN "0111",
    11.             "0000000" WHEN "1000",
    12.             "0001100" WHEN "1001",
    13.             "1111111" WHEN others;
    14.
  6. uchi28
    Aug 5, 2008
    hi guys
    can you help me, how to display the number in seven segment using vhdl for quartus II 5.0
    thx
