VHDL Project.
Discussion in 'The Projects Forum' started by throwitdown, Apr 17, 2004.
Thread Status:
Not open for further replies.
  1. throwitdown
    Apr 17, 2004
    Please help,
    I am i completely stuck on my project. I know what i want to do, but I am not sure where to begin by coding it.
    I am implementing a scoreboard using VHDL. I am using a XS40 board to run my code on. The code will count down like a sports scoreboard, and will show the clock counting down on the monitor using the on board VGA.
    I have written code which should count down from 12 minutes (12:00:00) to zero seconds, and now I have to figure out how I intend to show this on the screen.
    I have broken the monitor into blocks of pixels, 32 blocks across and 24 blocks down. This makes each block 10 pixels each horizontally and 20 vertically.
    i have then designed what each pixel would look like on the screen, using a box which is 4 blocks across (40 pixels) by 8 blocks down (160 pixels)
    So, in order to set up my design, I intend to have a counter which will count every 10 pixels horizontally for each block, then count every 4 blocks of 10 pixels for each block, then count across in digits. i similar operation would take place vertically.(values of 20, 8, and 3)
    I am sorry about not being able to explain this well, but i can post diagrams which will help explain this.
    I then intend to store in ROM, the addresses of each block, and whether it will be white or black, and then project it on to the screen. I know the value I have in each address, but I am unsure as to how to make sure they appear how I want them to using the VGA.
    I have no idea as to how I am going to implement my design in code. I am not an experienced programmer in VHDL and I only have another 2 weeks to finsh this project.
    Here is the initial code I have written for the counters, but have yet to simlute and synthesise.
    Library IEEE;
    use IEEE.STD_LOGIC_1164.all;
    use IEEE.STD_LOGIC_UNSIGNED.all;
    entity GAMECLOCK is
    port (
    CLOCK: in STD_LOGIC;
    RESET: in STD_LOGIC;
    RUN : in STD_LOGIC;
    DEC : in STD_LOGIC;
    umin: out STD_LOGIC_VECTOR (3 downto 0); -- 10
    lmin: out STD_LOGIC_VECTOR (3 downto 0); -- 1
    usec: out STD_LOGIC_VECTOR (3 downto 0); -- 10
    lsec: out STD_LOGIC_VECTOR (3 downto 0); -- 1
    umsec: out STD_LOGIC_VECTOR (3 downto 0); -- 1/10
    lmsec: out STD_LOGIC_VECTOR (3 downto 0)); -- 1/100
    end GAMECLOCK;
    architecture of GAMECLOCK is
    SIGNAL dec_umin, dec_lmin, dec_usec, dec_lsec, dec_umsec, dec_lmsec : STD_LOGIC_VECTOR (3 downto 0);
    begin
    lmsec:process (CLOCK, RESET)
    begin
    if RESET = '1' then
    lmsec <= "0000";
    dec_umsec <= '0';
    elseif CLOCK'event and CLOCK = '1' then
    if lmsec = "0000" then
    lmsec <= "1001";
    dec_umsec <= '1';
    else
    lmsec <= lmsec - '1';
    dec_umsec <= '0';
    end if;
    end if;
    end process
    umsec:process (CLOCK, RESET)
    begin
    if RESET = '1' then
    umsec <= "0000";
    dec_lsec <= '0';
    if umsec = "0000" then
    umsec <= "1001";
    dec_lsec <= '1';
    else
    umsec <= umsec - '1';
    dec_lsec <= '0';
    end if;
    end if;
    end process
    lsec:process (CLOCK, RESET)
    begin
    if RESET = '1' then
    lsec <= "0000";
    dec_usec <= '0';
    if lsec = "0000" then
    lsec <= "1001";
    dec_usec <= '1';
    else
    lsec <= lsec - '1';
    dec_usec <= '0';
    end if;
    end if;
    end process
    usec:process (CLOCK, RESET)
    begin
    if RESET = '1' then
    usec <= "0000";
    dec_lmin <= '0';
    if usec = "0000" then
    usec <= "0101";
    dec_lmin <= '1';
    else
    usec <= usec - '1';
    dec_lmin <= '0';
    end if;
    end if;
    end process
    lmin:process (CLOCK, RESET)
    begin
    if RESET = '1' then
    lmin <= "0010";
    dec_umin <= '0';
    if lmin = "0000" then
    lmin <= "0010";
    dec_umin <= '1';
    else
    lmin <= lmin - '1';
    dec_umin <= '0';
    end if;
    end if;
    end process
    umin:process (CLOCK, RESET)
    begin
    if RESET = '1' then
    umin <= "0001";
    if umin = "0000" then
    umin <= "0001";
    else
    umin <= umin - '1';
    end if;
    end if;
    end process
    end GAMECLOCK;
    If any one could help or requires more information, please let me know,
    Cheers,
    T
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Thread Duplicate.
    To ensure we don't have several different discussions about the same topic I am going to lock this thread and link to the other thread in the Programmer's Corner.
    Go here to reply to this topic.
    Thanks.
Thread Status:
