hey guys. Pulling my long beautiful hair out over this one
My class was assigned to write an ALU using mostly binary arithmetic, rather VHDL's built in functions. kind of a pain but rather educational. We're given 2 3bit inputs, plus a 3 bit input for selecting the functions.
So my ALU works. Except for one little tiny part on multiplication. Everything works beautifuly, except 7 x7. I dont get it.
The top half of my code, checks to see bit of the input_B, and AND's that to bring it down. i set up my vectors to go X, Y, Z
I would have preferred to simply read it as (Iput_A AND Input_B(0)) so on and so fourth, but this apparently isnt allowed? It errors out. Anyways. I "bypassed" that by using If Then.
The loop/lines of crazy math are the adders. This is where im thinking i have an issue?
so
But, this worked, until i enter 111 x 111
SO i tried to break it down completely manually in case i had an incremenet wrong with the loop
Alas, same result. Everything works perfectly. EXCEPT the entering of 111x111. The out put i SHOULD get is 110001. What i get is 101001. Where did i botch up? obvously my 4th bit isnt carrying over on this number?
So what am i doing wrong guys?
I know not the cleanest and most efficient of code, but im tryin!
Thanks in advance!
so
Rich (BB code):
101 --Input_A
011 --Input_B
101 --X
1010 --Y
10100 --Z
001111 --Sum
Carry(0)
Rich (BB code):
function Multiplication (A_Input, B_Input: std_ulogic_Vector(2 downto 0)) Return Std_ulogic_vector is
Variable x, y, z: std_ulogic_vector(4 downto 0):="00000";
variable sum, carry: std_ulogic_vector(5 downto 0):="000000";
begin --For whatever reason, VHDL won't directly compare a bit in a vector, so we manually break it down
--Compares the bits in B_Input and AND's A_Input down
if (B_Input(0) = '0') then
x(2 downto 0):= ("000" AND A_Input);
else
x(2 downto 0):= ("111" AND A_Input);
end if;
if (B_Input(1) = '0') then
y(3 downto 1):= ("000" AND A_Input);
else
y(3 downto 1):= ("111" AND A_Input);
end if;
if (B_Input(2) = '0') then
z(4 downto 2):= ("000" AND A_Input);
else
z(4 downto 2):= ("111" AND A_Input);
end if;
sum(0):=x(0); --Sets up bit(0) of the answer
for I in 1 to 4 loop --Finds bits 1 through 4 for the final result
sum(I):= x(I) xor y(I) xor z(I) xor carry(I-1);
carry(I):= (x(I) and y(I)) or (y(I) and z(I)) or (z(I) and x(I)) or (carry(I-1) AND x(I))
OR (carry(I-1) and y(I)) OR (carry(I-1) and z(I));
end loop;
sum(5):=carry(4);
return sum;
end Multiplication;
Rich (BB code):
sum(0):=x(0);
sum(1):=x(1) xor y(1) xor z(1);
carry(1):=(x(1) and y(1)) OR (y(1) and z(1));
sum(2):=x(2) xor y(2) xor z(2) xor carry(1);
carry(2):=(x(2) and y(2)) OR (y(2) and z(2)) or (carry(1) and x(2)) or (carry(1) and y(2)) or (carry(1) and z(2));
sum(3):=x(3) xor y(3) xor z(3) xor carry(2);
carry(3):=(x(3) and y(3)) OR (y(3) and z(3)) or (carry(2) and x(3)) or (carry(2) and y(3)) or (carry(2) and z(3));
sum(4):=x(4) xor y(4) xor z(4) xor carry(3);
carry(4):=(x(4) and y(4)) OR (y(4) and z(4)) or (carry(3) and x(4)) or (carry(3) and y(4)) or (carry(3) and z(4));
sum(5):= (x(4) and y(4)) or (y(4) and z(4)) or (x(4) and z(4)) or (carry(4) and x(4)) or (carry(4) and y(4)) or (carry(4) and z(4));
Thanks in advance!
