VHDL help using ispM4A5
Discussion in 'Programmer's Corner' started by lawdawg1993, Nov 1, 2013.
  1. lawdawg1993
    Oct 27, 2013
    Im trying to do a lab for a class and im having trouble getting started.
    Here is the lab: http://fac-web.spsu.edu/ecet/dwilcox/ECET1200/Labs/Lab_11.pdf
    What im having problems with is the following statement: "Use SW1 as a reset switch. Use SW2 as a
    pattern pause switch. All segments are active LOW. The CLK input should be the 4 Hz CLK1 located on pin
    How do i put that in vhdl?
