Hi dear all,
I m trying to wirte a VHDL code to approximate a simgmoid function. so far I have only get the positive values working properly, but the negative side outputs wierd plot once I use signed value.
my code is given below. help is appreciated coz I m doing this for a important project.
thanks in advance.
library IEEE;
use IEEE.std_logic_1164.all;
use ieee.std_logic_signed.all;
use ieee.std_logic_unsigned.all;
use IEEE.NUMERIC_STD.ALL;
entity Dsigmoid is
port (sigin: in std_logic_vector(16 downto 0);
sigout: out std_logic_vector(16 downto 0)
end Dsigmoid;
architecture DsigTf of Dsigmoid is
signal temp: integer range -511 to 511;
signal A1:integer range -511 to 511;
signal B1: integer range -511 to 511;
signal vTheta:integer range -65535 to 65535
signal vv: integer range -262144 to 262144;--std_logic_vector(16 downto 0)
constant L: integer range -255 to 255:=255;
constant M: integer range -1023 to 1023:=511;
begin
A1<=to_integer(signed(sigin));
B1<=M+A1 when A1<0 and A1>-L else M-A1;
vv<=B1*A1;
vTheta<=vv/256;
temp<=vTheta;
sigout<=std_logic_vector(to_unsigned(temp,17)) when A1<L and A1>0
else std_logic_vector(to_unsigned(temp,17)) when A1<0 and A1>-L
else std_logic_vector(to_unsigned(L,17)) when A1>=L
else std_logic_vector(to_unsigned(0,17));
end DsigTf
thanks in advance.
library IEEE;
entity Dsigmoid is
end Dsigmoid;
begin
vv<=B1*A1;
vTheta<=vv/256;
temp<=vTheta;
end DsigTf
