VHDL for comparator
Discussion in 'Homework Help' started by Predador, May 22, 2008.
  1. Predador
    May 22, 2008
    7
    i ned to make an VHDL of the behavior of this comparator
    can enibody help me...
    any recommendation of a good program to write and to test VHDL?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Quartus II from Altera.
    The download is almost 1GB so it will test your patience and your broadband connection.
  3. Predador
    May 22, 2008
    7
    i am triing Active-HDL 7.2SE to help me for this work
    yoiu think is good?
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I've never heard of Active-HDL, but concur with Papabravo's suggestion of Quartus II. Another alternative is ISEPack by Xilinx and test via ModelSim.
    Dave
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I'm unfamiliar with that package, so I can't comment.
  6. Predador
    May 22, 2008
    7
    i am having an hard time with this work
    1st i don't find what kind of comparator i am diling with.
    2nd i need to describe the beavior of this comparator in VHDL (i am not familiar with)
    3- i need to write an “testbench” in VHDl
    it is very hard with 2 classes of VHDL laguage to do it.
    can enibody put me in the right way...
    i am so:confused:
    thank you all for your help
    sorry for my bad english...
    i found this code seems to be like the one i need
    complet document
  7. aiken
    May 23, 2008
    1.use AND, OR,XOR gate to "draw" the circuit first!! Remember you are now doing digital design.
    2. Find from your notes or internet: how to write vhdl code for AND OR XOR gate then you should write your design by vhdl
    3. use ISE is better than Atlera one, becuase ISE support Testbench for simulation.
    4. If you want to write test bench faster, I will suggest you use Actel tools (because they use GUI interface to input signal and output vhdl code testbench for you
  8. Predador
    May 22, 2008
    7
    thank you all for your patience...
    whitch one of the ISE products you recomend, they ar very havy...
    and from actel
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The behavioral description would look something like
    Code ( (Unknown Language)):
    1.
    2. BEGIN
    3.  PROCESS (a,b)
    4.  BEGIN
    5.   IF    a<b THEN
    6.          result <= "001";
    7.   ELSIF a=b THEN
    8.          result <= "010";
    9.   ELSIF a>b THEN
    10.          result <= "100";
    11.   ELSE
    12.          result <= "000";
    13.   END IF;
    14.   agb <= result(2);
    15.   aeb <= result(1);
    16.   alb <= result(0);
    17.  END PROCESS;
    18.
    A behavioral description has some advantages over the structural when you are just getting started.
  10. Predador
    May 22, 2008
    7
    thank you for the tip Papabravo
    i hav dond it an little bit mor complex but i thinc it works
