VHDL BCD-to-Binary Encoder Question
Discussion in 'General Electronics Chat' started by royalt213, Jan 18, 2016.
Who is right, me or the other guy?
  1. Me
    0 vote(s)
  2. The Other Guy
    0 vote(s)
  1. royalt213
    Feb 27, 2009
    I was asked the following question:
    Write the VHDL assignment operator for the Y2 output (most significant bit) of a BCD-to-binary encoder. Use Boolean operators, D0-D9 as the data inputs lines, and Y0-Y2 for the outputs. Inputs and outputs are active-HIGH. Please note that ONLY one VHDL statement is needed, don't write a whole program.
    I am having several problems with this question:
    • First, wouldn't this need a Y3 to be able to represent all decimal digits?
    • Second, in that case, Y3 would be the most significant bit, right?
    When I brought up these questions, I got the response:
    If we have 10 input lines, which is 2^3 = 8 < 10 < 2^4 = 16. That means, we can use either 3 or 4 output lines. We have chosen 3 output lines in this case.
    But this doesn't make sense to me either. You can only "choose" 3 output lines if you don't want to represent 8, 9 and 10, right?
    Can somebody clarify this for me? Thanks in advance!
  2. Brownout
    Jan 10, 2012
    Using 10 bits, you can represent 399 (decimal) in BCD. No, the question doesn't make sense.
