Vhdl assignment...help please
Discussion in 'Homework Help' started by viip, Nov 6, 2009.
  1. viip
    Apr 16, 2009
    hii everyone.I got the following question as assignment but am not able to understand it fully...
    " Design a D-FF using 4:1 Mux as an internal block used for constructing NOR gate, Using structural VHDL code"
    Please give an idea how mux could be used for constructing D-ff...and what the question is referring about the NOR gate....
  2. Thav
    Oct 13, 2009
    I sounds like they want you to set up a MUX so that it would act like a NOR gate. The way you do this I think is to set the inputs of the "NOR" gate to the select bits of the MUX, and then set the other inputs (A0-A3) of the MUX basically to the truth table of a NOR gate.
    S0 S1 Y
    0 0 A0
    0 1 A1
    1 0 A2
    1 1 A3
    Does that make sense?
    I don't have enough experience with structural VHDL code to tell you more, but I'm guessing you'll have to use some clock'event structures. I just can't tell you which.
