VHDL adding two registers
Discussion in 'Programmer's Corner' started by gammaman, Apr 3, 2009.
  1. gammaman
    Feb 14, 2009
    29
    How would I add to registers together so that A=A+B.
    This is what I have so far.
    Code ( (Unknown Language)):
    1.
    2. Library ieee;
    3. Use ieee.std_logic_1164.all;
    4. Use ieee.std_logic_arith.all;
    5. Use ieee.std_logic_unsigned.all;
    6.
    7. Entity  Four_Bit_Register is
    8.     Port (
    9.         Clear        : in  std_logic;
    10.         Inc           : in  std_logic; -- x
    11.         Clock       : in  std_logic;
    12.         Cnt_in        : in std_logic_vector(3 downto 0);
    13.         Cnt_out        : out std_logic_vector(3 downto 0);
    14.         Load        : in std_logic);
    15. End Four_Bit_Register;
    16.
    17.
    18.
    19.
    20. Architecture Four_Bit_Register_Arch of Four_Bit_Register is
    21.
    22. Signal Cnt,A,B : std_logic_vector (3 downto 0);
    23.
    24. Begin
    25.  Cnt_out <= Cnt;
    26.
    27.   Count : Process( Clear, Inc, Clock, Load)
    28.
    29. Begin
    30.
    31.     if clock'event and Clock = '1' then
    32.        A<=A+B;
    33.     if Clear = '1' then
    34.              Cnt    <= "0000";
    35.     elsif Load = '1' then
    36.         Cnt <= Cnt_in;
    37.     elsif Inc= '1' then
    38.               Cnt    <= Cnt + "0001";
    39.          else
    40.              Cnt    <= Cnt;
    41.             End if;
    42. End if;
    43. End process;
    44.
    45. end Four_Bit_Register_Arch;
    46.
  2. DualCortex
    Apr 3, 2009
    A <= std_logic_vector(signed(A) + signed(B));
    The compiler will synthesize an adder accordingly.
