VGA to composite RCA cable
Discussion in 'The Projects Forum' started by OzSkunk, Jul 7, 2013.
  1. OzSkunk
    Jul 7, 2013
    13
    Hi there guys...
    Ive searched google high and low but to no avail. ..
    My laptop has tv out through the vga port capability..but I have no cable..I know I can buy a cable but would rather make one...
    Q. What pins on the 15pin vga connector need to be joined?
    Im guessing the 3 rgb outputs go to the centre pin on the rca..and the earths go to the outer of the rca..
    Cheers
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
    Did you try "VGA to composite" on Google?
  3. OzSkunk
    Jul 7, 2013
    13
    Yes looked at hundreds of pages..and theyre all the same...half saying it cant be done or buy one or u need a convertor etc etc...diagrams for component (not composite) or b/w etc...
    Its so basic but theres no clear info out there...
  4. Paul Kerry
    Member
    Jan 9, 2012
    36
    The information you require should be in the user guide or on the manufacturer of your laptops website, you maybe lucky!
  5. MrChips
    Oct 2, 2009
    12,652
    3,461
  6. OzSkunk
    Jul 7, 2013
    13
    Nope checked there...gives pinouts of the vga port but I need to know which pins to join where...
  7. OzSkunk
    Jul 7, 2013
    13
    Yeah ... I only need a passive not active connection. ..
    Its just a simple lead...
  8. MrChips
    Oct 2, 2009
    12,652
    3,461
    You cannot get colour composite with just a passive circuit.
  9. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You can not just join some pins.
    You will need a circuit like the one MrChips gave you.
    Bertus
  10. Paul Kerry
    Member
    Jan 9, 2012
    36
  11. OzSkunk
    Jul 7, 2013
    13
    Usually yes but the chipset I have does the conversion...
  12. OzSkunk
    Jul 7, 2013
    13
  13. MrChips
    Oct 2, 2009
    12,652
    3,461
    You can electronically combine the RGB signals along with the HSYNC and VSYNC to give you B/W composite.
    You cannot do the same to produce colour because you need to produce luminance and chrominance and you have to add colour burst signal.
  14. Ramussons
    May 3, 2013
    562
    92
    Ref: https://en.wikipedia.org/wiki/VGA_connector
    Your PC Cannot have TV Out on the VGA 'D' Port. The 15 pin connector will connect to only a display that has a 'D' connector.
    The signal levels on the EGA connector are Digital (0/5 Volts) whereas your TV input will be 1.0 V p-p (+.7 Video, -.3 Blanking)
    TV out can be on a RCA (composite video) or 'S' video output; and in some cases SCART.
    You will need to process the VGA output as MrChips has stated to derive a 'S' video out.
    Ref: http://www.wikihow.com/Use-Your-TV-As-a-Computer-Monitor
    Ramesh
  15. Paul Kerry
    Member
    Jan 9, 2012
    36
    It depends on which pin your laptops chipset uses when set to TV out, this is why I originally suggested your manufacturer. You may have to buy the correct cable for your machine if you can not find the information. Most laptops I've seen have an RCA socket on them for TV OUT, if it's supported.
    The driver may support TV out, but the hardware may not. It is not unknown for there to be one driver that supports several versions of one chipset. If your chipset does not have TV OUT, then the circuit by MrChips is the only way I can see of doing it.
  16. OzSkunk
    Jul 7, 2013
    13
    Yes thats how I thought it was done...buy using some of the unused pins..but then I changed to the idea it is combined. .
    Heres the pinout..not sure if its different or not
  17. Paul Kerry
    Member
    Jan 9, 2012
    36
    The Dell Vostro 1200 does not mention anywhere in the specs that it is TVOUT capable, the only way would be the one suggested by MrChips.
    Sorry
  18. OzSkunk
    Jul 7, 2013
    13
    Lets say if it did..how would it be connected?...
  19. Paul Kerry
    Member
    Jan 9, 2012
    36
    Knowing Dell there would either be an SVHS connector or RCA on the machine somewhere
  20. wayneh
    Sep 9, 2010
    12,403
    3,250
    Or a long lost rat-tailed adapter somewhere. ;)
