I was connecting my VGA cable from my monitor to my HP docking station when all of a sudden huge sparks come out of the port! The metal on the cable is melted back and some of the pins (15, 10, 5) are black.
I am assuming that the cable make contacted with the screw holes on the docking station. Now the VGA port on the station no longer works..it keeps on shorting out when I connect the other side to the monitor.
Monitor was not harmed, but I am scared to put in my laptop...what do you guys think?
I connect the monitor to my laptop and everything works...so I know that the cable is not at fault.
Edit:
I just remember that my docking station was plugged into an outlet that I had just previously done work on ( moved it).
Perhaps the wires got mixed up. Weird thing is that the charger still works fine, plus the laptop was later plugged into that same outlet and worked fine.
Maybe the GND pin on the VGA cable arched over due to faulty outlet wiring?
Edit:
