I've been stuck on trying to debug this code. I have used the MPLAB debugger and it seems to work perfectly but when I put it on the chip its not doing what I want. The code as is on my PIC is configured to have oscillation pulses to display pixels through a vga port. My GPIO 0, 1 and 2 act as a 3 bit binary counter to display colors and resets when GPIO 3 is high. So I basically display black through white each HSYNC pulse. My GPIO 4 bit outputs a HSYNC frequency at 29.57Hz which is a little low but I can eventually change it to be faster. My problem lies on the GPIO 5 bit which acts as my VSYNC. My code is configured to display a color band per VSYNC drawing at 60 frames a second. So the first second of drawing displays black, red and so on in sequence. While the next second would start with red instead of black but would cycle through all the colors.
For some weird reason my GPIO 5 bit is somehow being brought low within the main chunk of the code. The only time I set the VSYNC low is when I use the delay loop so that should give me around 60Hz. Instead I am reading 25.91KHz on my multimeter when I probe GPIO 5.
I'm using header file P12F675.inc and linker script 12F675_g.lkr fyi. Don't know if that could affect why it isn't working.
Any suggestions as to what is happening?
Rich (BB code):
list p=12f675 ; list directive to define processor
#include <p12f675.inc> ; processor specific variable definitions
__CONFIG _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
;*************************** REGISTERS ********************************
cblock 0x20
DelayCounter ; register location DelayCounter will contain number of loops that GPIO 5 is low
GPCounter ; register location GPCounter will contain status of color to be drawn per second
VSYNC ; register location VSYNC will contain number of loops before GPIO is set low
PixelCounter ; register location PixelCounter will contain number of loops per line draw
NA ; unused file location
ThreeCount ; register location ThreeCount will contain number of loops outside loops for VSYNC
endc
;*************************** CONSTANTS ********************************
#define Bank0 banksel 0x00 ; first registerr bank = Bank 0
#define Bank1 banksel 0x80 ;second register bank = Bank 1
#define ConfigTRI B'00001000' ; Configure I/O
;******************** INITIALIZATION PROTOCOL **************************
org 0x000 ; BIG BANG
goto Initialize ; Initialization call
org 0x005 ; Start of Programm Memory Vector
Initialize
Bank0 ; Bank 0 located at 0x00h
movlw 03h ; store 03 in
movwf ThreeCount ; ThreeCount
movlw 0A0h ; store A0 in
movwf VSYNC ; VSYNC which means VSYNC is set low when A0 * 3 loops have been iterated
movlw 07h ; store 07 in
movwf PixelCounter ; PixelCounter so 7 colors can be drawn per line
movwf CMCON ; CMCON so digital configuration is set
movlw 30h ; move binary value 00110000
movwf GPIO ; Hsync and Vsync are set by having GPIO 5,4 high
Bank1 ; Bank 1 located at 0x20h
clrw ; clear w register
clrf ANSEL ; clear ANSEL register which controls analog or digital configuration making DIGITAL
movlw ConfigTRI ; loads constant ConfigTRI
movwf TRISIO ; loads w register into TRISIO register which assigns I/O for GPIO pins
Bank0 ; return to Bank0 address
Main
incf GPIO,1 ; increments gpio every pixel draw showing all 7 colors
decfsz PixelCounter,1 ; when 7 colors are drawn then restart line
goto Main
movlw 20h ; move binary value 00100000 clears HSYNC
movwf GPIO ; clears GPIO 4
movlw 07h ; move 7 to register w
movwf PixelCounter ; PixelCounter gets reset to 7
movlw 10h ; move 10h to w
addwf GPCounter,0 ; add that value to color status
addwf GPIO,1 ; move the contents of w and GPIO into GPIO setting first color draw
decfsz VSYNC,1 ; decrement VSYNC
goto Main
movlw 0A0h ; resets VSYNC with
movwf VSYNC ; A0h
decfsz ThreeCount,1 ; decrements ThreeCount
goto Main
movlw 03h ; move 3 to register w
movwf ThreeCount ; reset ThreeCount
clrf GPIO ; clear GPIO for Hsync and Vsync low pulse
movlw 49h ; move 49h to
movwf DelayCounter ; DelayCounter which sets Vsync's low time
;Vsync and Hsync low pulse
DelayLoop ; This loop will eventually be used to configure pixels
nop
nop
nop
nop
nop
nop
nop
decfsz DelayCounter ; decrement until DelayCounter is 0
goto DelayLoop ; then skip loop
incf GPCounter,1 ; increment GPCounter which keeps track of color to be drawn first
btfsc GPCounter,3 ; check GPIO bit 3 and if set reset color sequence to original
call RGPCounter ; reset GPCounter
movlw 30h ; set Hsync and Vsync to start drawing again
addwf GPIO,1 ; add it to GPIO
movf GPCounter,0 ; move contents in GPCounter to w
addwf GPIO,1 ; add w and GPIO and then place in GPIO register
goto Main ; return to main loop
RGPCounter
movlw 00h ; move binary value 00110111
movwf GPCounter ; Hsync and Vsync is set being the 5th and 6th bit on GPIO
return
end
