VGA monitor from C program
Discussion in 'Embedded Systems and Microcontrollers' started by bivosky, Dec 2, 2014.
  1. bivosky
    Dec 2, 2014
    i can't understand how i can use the vga monitor like lcd or glcd. and with C language.
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    Your post was moved from here.
    You really need to start a new thread.
    Also your question is not clear. Please explain what you are attempting to do.
  3. ISB123
    May 21, 2014
    1,240
    531
    He wants' to connect microcontroller with a PC VGA interfaced monitor.Normally you would use serial for LCD and LED screens .I could be wrong but I think that you cant do that since monitors require graphics card,maybe its possible but I'm not sure.But if its possible its probably not direct and would require external components.
  4. MrChips
    Oct 2, 2009
    12,623
    3,451
    If you want to drive a VGA monitor directly from a microcontroller it can be done as both RB and I have demonstrated. But you have to be able to jump through hoops and over hurdles in order to accomplish that feat.
  5. shteii01
    Feb 19, 2010
    3,500
    511
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Anything can be bit-banged if your processor is fast enough and you have earned your programming bona-fides.
    panic mode likes this.
  7. ISB123
    May 21, 2014
    1,240
    531
    He could use average hobbyist microcontroller to render 100x100 pixels anything above that is too much for MCU.For full screen resolution you would need something with much bigger processing power.
  8. WBahn
    Mar 31, 2012
    18,079
    4,917
    That would depend on what else you are asking it to do. About 15 years ago PIC-Pong was done using a PIC16C71 that produced NTSC-like output (256 line non-interlaced) directly via bit-banging in addition to running the code to play Pong, including the necessary character generation for the text.
    ISB123 likes this.
  9. nigelwright7557
    May 10, 2008
    488
    71
    You really need a video generator circuit.
    You put data in its memory and it displays it for you.
    I remember many years ago using a simple PC graphics card directly by poking data into its memory.
  10. shteii01
    Feb 19, 2010
    3,500
    511
    http://tinyvga.com/avr-isa-vga
  11. MrChips
    Oct 2, 2009
    12,623
    3,451
    Did you see this? What the heck is that? Looks like a kludge for a crystal oscillator if you ask me.
  12. ErnieM
    Apr 24, 2011
    7,434
    1,625
    The Maximite is a PIC microcontroller project which gives a VGA output for a 480 x 432 color display directly no using video generator circuitry beyond a few resistors and a connector.
    I have not examined the source code to discover what high level language it is written in, but it certainly could be done in C/C++.
  13. shteii01
    Feb 19, 2010
    3,500
    511
    Here is PIC doing CGA: http://tinyvga.com/pic-vga
