VGA Challenge
R!f@@
Joined Apr 2, 2009
9,918
Take a look at the pick
First check the RGB wire for an additional ground shield inside.
Second use the meter continuity check range to find out where the rest of the wire leads to on to the VGA board.
Identify them and mark them properly and post it.
{ed}
Oh by the way. You have to plug in the VGA connector to the board
R!f@@
Joined Apr 2, 2009
9,918
OK Now comes a tricky part. With the VGA cable removed, put the monitor back as it was, I need some voltage measurements.
I have to know the DC voltage available at the color coding when the monitor is showing a test screen
{ed}
Or better yet you can measure them at the end of the cable, this way is easier
The monitor should be on, not in stand by. If it goes to stand by. Connect meter, power on and measure. really soon
dannybeckett
Joined Dec 9, 2009
185
Im off to take an electronic and electrical engineering test now for my degree, heres some progress I made last night. The following is info about the pins in the picture:
#1 to MYSON MTV312MV64 Chip
HSCL/P3.0/Rxd || I/O || Slave IIC clock / General purpose I/O / Rxd (open drain)
#2 to MYSON MTV312MV64 Chip
HSDA/P3.1/Txd || I/O || Slave IIC data / General purpose I/O / Txd (open drain)
#3
DA5/P5.5 || I/O || PWM DAC output / General purpose I/O (CMOS)
#4
Pin > 100R resistor > Q buffer D > transistor
#5
Pin > 100R resistor > D inverter Q' >
This is as far as I have got, i'll be able to do more, and get some voltage measurements for you after this exam.
R!f@@
Joined Apr 2, 2009
9,918
Pin 3 could be a monitor info pin. It's an IO, so could be anything
The trick is to connect the RGB correctly ( if not only color error will show but there will be a picture)with the respective ground.
Connect all the ground.
Apply a 800 by 600 VGA resolution from the VGA card and connect HV sync one by one. Swapping will definitely identify the sync signals. U have to look in to the VGA diagram at rj post.
The monitor may go in to stand by without HV sync, you need to power of the monitor fro HV sync swapping.
Once established this connections. Connect the SDA and SCL properly.
Monitor ID have to be trial and error and to make these connections certain you need to restart windows after each connection as the VGA driver loading will identify the monitor model for proper sync and resolution refresh rates settings, and also to display the monitor model in the info tabs.
Remember first you need to establish RGB and sync, proper colour and to make sure apply the monitors native resolution to see if it works, if not then you need the other connections too, if it did then you are in luck. Make these connections permanent before any other connection.
And always reduce the resolution to standard VGA resolution to avoid confusion to the graphics card if it supports monitor ID signals.
dannybeckett
Joined Dec 9, 2009
185
Made progress guys!
Attached pic for info. Managed to trace back 2 inputs to vsync and hsync. now with sda and scl i only have 2 wires left - ID0 and ID2. I should just try them one way and then try them the other?
This has been a great success guys, very much appreciated the effort you have put in. Big thanks to R!F@@.
Last question, I have no Sync Ground (pin10) - is this normal?
Heres the content of text file i made whilst tracing the wires back
THIN GREEN
THIN BLUE
THIN PURPLE
THIN BLACK (THROUGH A RESISTOR AND A TRANSISTOR)
DA2/P5.2 || I/O || PWM DAC output / General purpose I/O (CMOS)
THIN RED
VSYNC
THIN ORANGE
HSYNC
Heres the updated image
Hopefully people in my position will be able to read this thread and sort themselves out =]
R!f@@
Joined Apr 2, 2009
9,918
Sync does not use an independent ground, it uses the normal ground as other data lines.
The RGB has an internal ground to isolate it from the next video line.
Have you been able to see a picture yet
dannybeckett
Joined Dec 9, 2009
185
Ahh good stuff, thats all the cables ID'd now =]
I am waiting on an order of a spare vga cable I am going to splice that I got off ebay. I will post back progress as soon as its made!
dannybeckett
Joined Dec 9, 2009
185
Oh before I get that VGA cable - the two sync pins from the myson chip went through two schmitt not gates each, before reaching the vga pins - what is the point of inverting a digital signal, then inverting it right back again?
