VGA Challenge
Discussion in 'General Electronics Chat' started by dannybeckett, May 23, 2010.
  1. dannybeckett
    Thread Starter Active Member
    Dec 9, 2009
    163
    Hi guys.
    I have a flatscreen monitor with a VGA output. The VGA cable, monitor side, is connected to the monitor via header on the monitor motherboard (no VGA socket. The other end of the cable has been snipped. I would like to buy a new vga cable and splice them together - but the colour of wires are not universal.
    Is there any way, using a function generator, oscilloscope and multimeter, that I can find out what cable does what (so I know how to splice the new end on)? I know where 6 of the wires go - red analog, green analog, blue analog and their respective returns - they are easily identified by their colour (only bit which is universal) and the fact they have a ground sheath around them.
    Heres a pinout for VGA
    http://en.wikipedia.org/wiki/VGA_connector
    Any help is massively appreciated
    Dan
  2. dannybeckett
    Dec 9, 2009
    163
  3. R!f@@
    Apr 2, 2009
    8,792
    771
    so how are you doing?
  4. dannybeckett
    Dec 9, 2009
    163
    I still need a way of identifying what wire has what function coming from the monitor, bar the 6 I have mentioned
  5. jamjes
    Member
    May 10, 2010
    35
  6. dannybeckett
    Dec 9, 2009
    163
    ahh excellent. yeah it works natively at 1024x768. how do i go about identifying h and v sync?
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    What is the brand and type number of the monitor?
    Perhaps there is a schematic for it.
    Bertus
  8. rjenkins
    Nov 6, 2005
    1,015
    69
    Are there any other cores that are screened, or using twisted pairs?
    How many other none-ground signals are there?
  9. dannybeckett
    Dec 9, 2009
    163
    @ bertus - its a GNR F153. its pretty old. the circuitboard that the vga cable connects to is "LCT-M 94V-0"
    @ rjenkins - nothing else is twisted or screened. I have attached pics so you can see the wires themselves. the 3 thick ones are the screened analog RGB cables. Im not sure which other ones are grounds
    Thanks again guys
  10. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I could only find a specsheet at the moment:
    Max. Resolution
    XGA 1024 x 768
    Scan Frequency
    Horizontal: 30kHz - 60kHz
    Vertical: 50Hz - 75Hz
    Bertus
  11. dannybeckett
    Dec 9, 2009
    163
    im guessing that frequency comes from the graphics card and not the monitor?
  12. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Yes, the two frequencies come from the videocard.
    In the old days with a CRT monitor those where the scanspeeds of the trace.
    In LCD monitors the frequencies are used to derive to dot speed and the dot position.
    Bertus
  13. dannybeckett
    Dec 9, 2009
    163
    ahhh i see. can we use this info to identify any other wires?
  14. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Do you have the rest of the cable?
    (the piece that was cut off).
    When you connect this to a video card you could measure the signals with an oscilloscope.
    Bertus
  15. R!f@@
    Apr 2, 2009
    8,792
    771
    Are u up to this. If so find some heat shrink sleeving that fit's those wires or some insulation tape and find a way to solder. I can guide you the connection with my eyes closed. Hopefully
  16. dannybeckett
    Dec 9, 2009
    163
    Unfortunately bertus I dont have the rest of the cable - if i did i could use a multimeter to check and see what wire goes where =[
    R!f@@ I am good with electronics, I can solder well. I have plenty of insulation tape. All I need to know is how I can find out the purpose of each wire coming from the monitor so I can splice a new end onto it. Ive checked the pinout of the genesis gmZAN2 chip and found vsync and hsync, but I cannot find continuity between those pins and any of the VGA wires which is odd.
  17. R!f@@
    Apr 2, 2009
    8,792
    771
    the picture shows which wire. Show what you wanna do and what have clearly
  18. dannybeckett
    Dec 9, 2009
    163
    The wire in the picture is the end of the monitor cable. I will draw a diagram of what I need to do. I hope this helps.
  19. dannybeckett
    Dec 9, 2009
    163
    so i need some way to determine the functions of those wires.
  20. R!f@@
    Apr 2, 2009
    8,792
    771
    OK that's good. Now show me the connection where the VGA cable terminates at the monitor ckt board
