I bought a ceiling bracket which does not have enough diameter to let this cable with its end connector pass through. is there a VGA cable with a narrow connector in the middle for disconnect/re-connect?...if it's causing you some physical problems in a mounting situation you can find cables without them.
Thread starter | Similar threads | Forum | Replies | Date |
Flexible cable | PCB Layout , EDA & Simulations | 1 | ||
Co-axial connector, twin axial cable | General Electronics Chat | 15 | ||
D | UART max cable length | General Electronics Chat | 19 | |
M | Can anyone identify this cable/connection? | Datasheets, Manuals & Parts Identification | 1 | |
Ribbon cable | General Electronics Chat | 2 |
