Very Very Simple Blinker LED
Discussion in 'General Electronics Chat' started by scytheye, Dec 26, 2007.
  1. scytheye
    Nov 27, 2007
    10
    Hey all - Is it possible to build a blinking LED circuit using only capacitors and resistors? Would diodes help, I pulled some out of a TV but don't know their values...?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The short answer: no, unless the flasher is built into the LED itself.
    Slightly longer answer: you need some kind of valve or semiconductor to sense when the voltage across the RC network has exceeded a certain threshold level, determined by the designer of the circuit. The valve or semiconductor then turns on the LED while draining the voltage from the RC network, until it has fallen below another threshold level.
    As mentioned in the short answer, there ARE self-flashing LED's. These have a timer circuit and current-limiting features built in. You can actually use them to flash a pretty long string of LED's.
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    For use with scrap parts and two npn transistors, use a meter to figure out which parts will work. Learn how to read capacitors or get a meter that will read them.
    http://xedox.de/blinker.htm
    Simplest two I've seen that work with 1.5v
    http://www.discovercircuits.com/DJ-Circuits/ac14fls.htm
    Lasts six months
    Vampires that cell
    http://www.discovercircuits.com/DJ-Circuits/1vled3.htm
    Lasts 12 months
    LM3909 is obsolete and hard to get but the others circuits are cool.
    http://ourworld.compuserve.com/homepages/Bill_Bowden/page10.htm#15flash.gif
