VERY URGENT HELP ABOUT COMMON-COLLECTOR AMPLIFIER??
Discussion in 'General Electronics Chat' started by dogar sahab, Oct 24, 2008.
  1. dogar sahab
    Thread Starter Active Member
    Mar 15, 2008
    116
    In common-collector amplifier
    I want to ask that
    If I place capacitor instead of resistor at the output,will amplification take place??
    and if not then why???
  2. dogar sahab
    Mar 15, 2008
    116
    here is the schematic from the site's book:
  3. dogar sahab
    Mar 15, 2008
    116
    I also want to ask
    If I short-circuit the emitter-resistance(Rfeedback),what would be the effect on output side????
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Your question is concerning a common-collector transistor stage. The diagram you have posted is that of a common emitter stage.
    Which amplifier configuration is you question about?
    hgmjr
  5. dogar sahab
    Mar 15, 2008
    116
    oh sorry..I want to ask about COMMON-COLLECTOR cofiguration..
    I just want to make my question clear..I didnt have a complete look!!!
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is a Common-collector stage. Is this what you had in mind?
    hgmjr
  7. dogar sahab
    Mar 15, 2008
    116
    perfectly!!!!
  8. dogar sahab
    Mar 15, 2008
    116
    hgmjr..would u plz come on messenger..I wnat to ask few Q..I have viva tomorrow!!!
  9. dogar sahab
    Mar 15, 2008
    116
    another Q is that,
    If i have capacitor attached on the collector,what would be the effect on output!!!??
  10. hgmjr
    Jan 28, 2005
    9,030
    214
    The answer to your question is that there would be no effect on the output.
    The output of a common-collector transistor stage is taken from its emitter.
    hgmjr
  11. dogar sahab
    Mar 15, 2008
    116
    and Q
    If I short-circuit the emitter resistance which is Rload in your figure,what would be the effect on output!!!??
  12. hgmjr
    Jan 28, 2005
    9,030
    214
    Your question is not crystal clear.
    If I understand it correctly, then the output would be grounded and the transistor would probably be destroyed.
    hgmjr
  13. dogar sahab
    Mar 15, 2008
    116
    ok..you have rightly understood my Q and I have got your answer!!!
    plz help me out in DIRECT-COUPLED COMMON-EMITTER COMMON-EMITTER (CASCADED AMPLIFIER)???
  14. dogar sahab
    Mar 15, 2008
    116
    I cant find it in the book on this site about direct-coupling??
  15. hgmjr
    Jan 28, 2005
    9,030
    214
    What is your question concerning a direct coupled common-emitter amplifier? Do you have a specific circuit diagram to use to aid in the discussion?
    hgmjr
  16. dogar sahab
    Mar 15, 2008
    116
    actually I have diagram in my book but I dont have scanner to make u see that!!!
    It's a simple DIRECT COUPLED CASCADED MULTISTAGE AMPLIFIER in which two COMMON-EMITTER TRANSISTORS are directly coupled!!!
    In that case
    If I short-circuit the emitter-resistance,what would be the effect on th output voltage waveform??
    and the other Q is that
    If i connect a capacitor on the collector side in that configuration,will still the amplication take place????
  17. hgmjr
    Jan 28, 2005
    9,030
    214
    Without a schematic of the circuit, it is difficult to determine which of the two emitters you are referring to.
    hgmjr
  18. dogar sahab
    Mar 15, 2008
    116
    I have found the circuit in the site's book:
    i have just 2 stages not 3...
    just add resistance in the emitter side in first transistor as well as second!!!
    and then my Q would be clear to u!!!
  19. dogar sahab
    Mar 15, 2008
    116
    ^this was the circuit I was asking!!??
  20. dogar sahab
    Mar 15, 2008
    116
    and there is no CAPACITOR in between the transistors..obviously i dont need CAPACITOR COUPLED MULTISTAGE AMPLIFIERS!!!
